Your door lock switch assembly has gone bad. It is an easy fix.
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washimy frigidaire affinity front load washer stopped s - 2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Hello garrett_lind, I appreciate your inquiry!
From my understanding you are searching for the pressure calibration switch on your Frigidaire washer due to the fact that it is not spinning on the last cycle. Some possibilities as to why your appliance is not spinning could be your timer or drain pump. I could not locate steps to access the pressure switch but for electrical components I would recommend having a professional come out to properly diagnose and repair the appliance. -Matt
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
my affinity washer will start then click off
