Nokia N800 Tablet PC Logo
A
Anonymous Posted on May 14, 2010
How to repair LCD screen of Nokia N800? - Nokia N800 Tablet PC
2 Related Answers
hardkiller
Heraki Era
  • 24 Answers
  • Posted on May 26, 2008
SOURCE: Lcd screen problem
if the lights didn't off, maybe your N800 is grounded. return it for repair.
Anonymous
  • 149 Answers
  • Posted on Sep 03, 2009
SOURCE: Nokia N800 screen problem
This is an issue the N800. You have to replace the LCD.
The screen on my Nokia 2520 tablet is black is black
Hi, your LCD (that what gives the display - picture ) needs to be replaced...you will have to hand it in at a repair shop
My nokia n800 keep startin over and over what the hell happen to it?
remove the battrey and connect it again.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Scrolling desktop; scrolling programs
This was a common problem that N800's had. From what I've read, requires an lcd replacement.
It was always difficult for me to switch on/off Nokia N800 as its button seemed too soft and fragile. And now I've been using Nokia N800 for 8 months and yesterday its button stopped reacting! It wouldn't...
Do you hear "clicking" when you press the power button? As if it registers the button but does nothing after the "click?" If not, then it sounds like the mechanical/electrical problem with the button. If you do hear clicking maybe if you simply do a battery pull it may reset what was freaking out the power button.
There is a way to reset the UI (rather than cycling the power) but it involves from shell commands:
the XTerm is in the utilities menu. Open that up and type:
/etc/init.d/mce restart
/etc/init.d/osso-systemui restart
Also in XTerm
shutdown -r now
will reset the N800.
Hope this helps,
Bill
1helpful
2helpful
Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
3answers
Stylus replacement needed
I guess you need to contact the company directly. Check the link to 'Contact Us'. You can call them up or e-mail.
Try it. Good luck...
2answers
Lcd screen problem
Pictures
Navigate to the site with the pic's you want, hold down the stylus on the image, and select "Save.."
Top Nokia Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Nokia Tablet and eReader Expert? Answer questions, earn points and help others
