Question about Makita Drills
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the usual 240 Volt AC. On the charger circuit board next to the transformer wire connection is a component marked F2; this is a 2.5Amp fuse covered with heat-shrink sleeving. This fuse had ruptured/blown. Also blown was Transistor Q1, a ''P'' Mosfet labelled IRF9Z24N and Schottky Diode D9 labelled SR560. Replacing these 3 items got the charger working again. NB Resistor R31 is only 0.1ohm - don't assume it's gone short circuit! NB. I'd presume that most other Makita chargers will have this heat-shrink sleeving ''camoflaged'' fuse on the input of the circuit board and it would definitely be worth checking if the charger has stopped working. Regards Roy
    Problem Solver:
I have a BL1830 Lithium Ion LXT battery that will not charge because the charger tells me the battery is broken. I have taken the battery apart to find no problems with the connection from cell to cell. There is a small circuit board that I cant find any visible signs of damage on. The battery will still run a flashlight or a drill but it is almost drained.
Posted on Aug 11, 2010
SOURCE:
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
May 11, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I've tried this charger on 3 batteries and always get "check connection" light, and flickering "battery charged" light. I've pinched clamps and connections are very good...I've left...
Smart chargers will fail to charge completely discharged battery. Simple charger w/o electronics will. Try connecting two batteries together with charger. ALL in parallel. + to +, and - to -.
Mar 03, 2018 | Minn Kota MinnKota MK110P Marine Portable...
Where can I get a schematic diagram of Makita DC18RA Charger?
my battery charger ic broken for a.c power flechuvation so iam not seeing that i.c number so i will ask you model DC18RA
Feb 14, 2011 | Makita DC18RA Rapid Battery Charger For...
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
Apr 18, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Charger not powering up, fuse is good?? what the f---?
Internal board fuse checked? This may/may not help?
Oct 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Charger no light and wont charge
Sorry to give you my opinion, but these chargers are very delicate, I have 4 and can barely keep 2 going. My recommendation? Open it up and look for obvious shorts/loose wires, if no luck then buy another one and return the busted one as if it were the new one. You will end up with two working chargers. PS this is probably fraud...ha!
Matt Giantglobes.com
Mar 10, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Drills Logo
551 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
