I have a trail blazer. i started it and it will not shif out of park, and when i shut it off the ingtion will not go all the way back and i cant get the key out.
Re: i have a trail blazer. i started it and it will
Check the shift interlock, it is designed to keep the vehical in park until the brake is depressed. Try turning the steering wheel (both ways if necessary) as you turn key to remove it
Check and see if your security light is flashing. One failure mode of the security system is a a quick start and shut down. If your security light is on or flashing and doesnt go out- that may be your problem...
you might want to check to see if you got a timming chain or belt in that car. but check that area first . could be a broken timming belt. you need to remove the dust cover in that area . check for no belt present on the timming gears. good luck,Gary
Could be the brake switch or the shift lock solenoid. You may be able to turn the key lock to the unlock position, move the shifter out of park, then start the engine in neutral. The shifter and the shift lock solenoid would need to be inspected.
Have the shifter linkage checked. Sometimes the linkage gets damaged or loose and doesn't go all the way into park. This can keep the keep the key from turning.
On 05+ Trail Blazer, the fuel filter is integral with the fuel pump inside
of the fuel tank. It is a non-serviceable part. On 02-04s, the filter is
on the drivers side frame rail at about the B-pillar. If your trail Blazer is a late 04 which means that it was build close to the 05 Trail Blazer, you may have a non serviceable fuel filter. Good luck and check under your Trail Blazer or look at your manufactured date sticker on the door which would help you indicate if your 04 is a early Trail Blazer and you'll have the fuel filter on the inside frame rail under the driver's door.
The weep hole of the water pump may be leaking. You see the water drip at the lower part of the front of the engine. After you park the truck, slide under the front of it and with a flash light look at the bottom of the water pump and see if you see a trail of water happening there.
