Question about Knowledge Adventure Jump Start World 2nd Grade (PC)
Bot jumpstart advanced for second grade. compatible with windows 7. installed ok. when i go to log in it gives me WINHTTPCONNECT:ERROR 6 and followed by ERROR REQUESTING AUTHENTICATION. Tech support says its a windows firewall problem on my PC but they cant tell me what to do to fx. Help.
How can I fix the runtime error I'm having on jumpstart 3rd grade on my windows xp?
Recommendation:
* Right-click on My Computer, then left-click on Properties.
* Left-click the Advanced tab at the top.
* Click the Settings button under the Performance heading.
* Click the Advanced tab at the top.
* Click the Change button to change the virtual memory.
* Write down the numbers that are currently set.
* Change the initial size to 512.
* Click the Set button.
* If you are asked to reboot, say Yes.
* If you're not asked to reboot, click OK on each window to get all the way back to your desktop, and then reboot your machine.
* When the computer restarts, try the game.
If the game fails to run and gives you the same error, please follow the instructions above and set the initial size to 256. Reboot the machine and try the program again.
As a last resort set the virtual memory to a large number such as 4000 or more and then try the program after rebooting. If this works you can drop the virtual memory by small increments until the error reappears then re-set it to the last good number.
May 23, 2017 | The Computers & Internet
How do I fix The drivers for this device are not installed. (Code 28) for windows XP
you probably installing a wrong driver.. look for the correct vendor and model.. and make sure it compatible with your operating system (Windows xp / 2k / 98 / ME / 7 / else)
hopefully this give you a jumpstart..
Aug 28, 2011 | Microsoft Windows XP Professional
I have a problem in downloading sound driver for window7
There are no officially supported Windows 7 drivers for the Acer Aspire 5570 notebook. However, the Vista drivers should work just fine.
If you don't know whether you have 64 bit or 32 bit Windows 7, then please follow these steps.
1. Press Win+R to open the Run command.
2. Type "MSINFO32" into the dialog box and press enter.
3. Look for item "System Type" and note whether the value is x64 or x86. (x86 means you have a 32 bit OS)
Regardless of whether you have 32 bit or 64 bit Windows 7 follow these instructions:
1. Go ahead and download 32 bit Windows Vista drivers by following the link: Acer Aspire 5570 Audio Drivers
2. Save file to the Desktop for easy access.
3. Extract ZIP file to Desktop.
4. Open the extracted folder.
5. Right click on the file "Setup" and select "Properties".
6. Select the Compatibility tab and check the box for "Run this program in compatibility mode for Windows Vista (Service Pack 2)". Click OK.
7. Double click the "Setup" file to run the installer. If the installer completes, then restart the computer and play a music file to see if you have sound.
If the installer fails, then follow the next set of directions:
1. Press Win+R to open Run command.
2. Type "DEVMGMT.MSC" and press enter.
3. Look for a device that has a yellow exclamation point next to it. If you have more than one, look for a device that says "Multimedia Audio Controller".
4. Right click on the device that has a yellow exclamation point next to it and select Properties.
5. Click the Driver tab and select Update Driver.
6. Click "Browse my computer for driver software".
7. Select "Browse...".
8. Browse to the extracted folder and select the "Vista" folder if you have the 32 bit version of Windows. If you have the 64 bit version of Windows, then select the "Vista64" folder. If Windows tells you there are no compatible drivers after step 9, then select the WDM folder and repeat step 9.
9. Click OK and then click Next.
10. Ignore all errors that Windows may give you and install the driver, restart the computer, and try to play a music file.
Good luck, post back if you have any difficulties, and thanks for using FixYa,
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
This is a game created for Windows 95/98. How do I run it in Windows Vista?
By default it should work, but some games would need you to change its compatibility. After you install it, right click the shortcut on the desktop and go to properties. After that click the compatibility tab, then check the box for 'Run this program in compatibility mode for:" And pick WIndows 95 or 98.
Feb 25, 2011 | Knowledge Adventure JumpStart 2nd Grade...
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
Installing Easy Grade Pro v. 3.5.6 on a machine with Windows 7. When install completes and we enter the serial # and name we get an error message that says there was an error saving the registration file....
right click on easygrade pro, select properties, go to the compatibility tab, choose run in compatibility mode as windows xp (service pack 3), start easygrade pro and try to reenter the serial number.
Mar 03, 2010 | Orbis Software Easy Grade Pro (EGPSING-W)...
How to delete names on Jump Start Advanced 1st grade?
The Knowledge Adventure page makes this suggestion:
Recommendations:
· JumpStart: Most of the JumpStart programs have a keystroke combination like CTRL+D+D to delete one user at a time from the sign in screen. See the manual for more information regarding the software. Other JumpStart programs have a delete button directly on the sign in screen.
CTRL+D+D didn't work for me on JumpStart Kindergarten, but CTRL+ Delete did!
Feb 24, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
I installed the CD for Jumpstart Spanish 1st-3rd grade- 2nd edition but at the end of installation, I got an error message about needing at least 3mb of memory and then it ends installation and the program...
To fix, try this
Right-click on My Computer icon, and select Properties.
Click on the Advanced tab,
then select the Settings button within the Performance section.
In the Performance Options window, click on the Advanced tab, and then select the Change button in the Virtual Memory section.
Click the Custom size button...
Change the Initial size (MB) setting to 4000
Change the Maximum size (MB) setting to 4000
Select SET to accept the change, which will close the Virtual Memory window. Select OK to close the Performance Options window. And select OK to exit the System Properties window.
please rate my solution
have a nice day.
Jul 07, 2009 | Jump Start JumpStart Spanish...
Error 80004004 trying to download windows messanger
Hey, i got myself on this issue since the new update of live messenger, i remembered playing with permissions because my windows wouldn't start and made the whole C:/ drive under my ownership and yeah solved this by getting a full control permission for the Local Services
1- open computer in start
2- right click on C: drive (or whatever drive windows's installed on)
3- properties <<Security tab>>
4- click (for special permissions or advanced settings click advanced)
5- look for LOCAL SERVICE and click change Permissions (you might not see it if not skip after 8
6- click on LOCAL SERVICE and click edit
7- check the full control box. click OK (you're back to the page of 6)
8- Check the box at thhe bottom Replace all Child object..... click ok and click continue on all prompts
6- Click on Add... in that window there's another advanced...click it
7- In the popup window on hte right side of common queries click <Find Now>
8- In the search results at the bottomthere should be LOCAL SERVICE click on it and press OK on top of the search results click OK in the small window
9- Click the first checkbox and choose OK
10- Check the box at thhe bottom Replace all Child object..... click ok and click continue on all prompts
This is also good for Windows Installer error 2203 and got this solution http://social.msdn.microsoft.com/forums/en-US/winformssetup/thread/56007f34-8f61-4336-a6ab-9328cca0c78e this Wont get WLM to work reason why i went directly to the whole drive good luck all
Feb 24, 2009 | HP iPAQ RZ1710 Pocket PC
Can I use the PDC 1100 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 1100 camera. Follow the instructions below to reinstall the PhotoMAX software and camera drivers using Windows XP's Program Compatibility Wizard. 1. Insert the PhotoMAX CD-ROM in the CD drive. If the program begins installing, press OK to close the "not compatible with Windows NT" error message. 2. Start the Wizard by clicking the Start button and choosing All Programs > Accessories > Program Compatibility Wizard. Follow the on-screen prompts. 3. On the second screen, select I want to use the program in the CD-ROM Drive and click Next. 4. Select Microsoft Windows 98/Windows Me and click Next. NOTE: You may have to scroll down to see this option. 5. Uncheck the following items: * 256 colors * 640 X 480 Screen Resolution * Disable Visual Themes 6. Click Next. 7. Click Next again. The PhotoMAX software will begin installing. Follow the on-screen prompts. 8. Follow on-screen prompts to finish the installation and click Finish. 9. When the Compatibility Wizard asks if the program worked correctly select Yes and click Next. 10. When the program asks if you want to send information to Microsoft, select No and click Next to finish the installation. 11. Shut down and restart the computer. After the restart, you should be able to download photos using Windows XP.
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Knowledge Adventure Jump Start World 2nd Grade (PC) Logo
64 people viewed this question
Top Knowledge Adventure Video Game Consoles & Games Experts
ray gallant
ray gallant
Brett Duxbury
Brett Duxbury
Are you a Knowledge Adventure Video Game Console and Game Expert? Answer questions, earn points and help others
