Will a hauppauge 950q usb tuner work with att uverse tv
SOURCE: WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
SOURCE: I have a Hauppauge WinTV-HVR-1600 running windows XP
Most likely, all stations in your area have switched to Digital Transmission, and your card can no longer find any. If that is the case, then you need a new card (they are not convertable) sorry.
SOURCE: Dell? Hauppauge WinTV-HVR-1250 TV Tuner
Make sure you have the remote sensor plugged all the way into the connector on the card. Also check your taskbar for the "remote" icon which confirms you have "irblaster32.exe" installed.
