Apple iPod touch Logo
Posted on May 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot unlock when turning ipod on it says connect to itunes, plugged it into the computer and itunes say cannot unlock, because it is locked with a pass code, but it wont let me in to put in a pass code
Anonymous
Level 2:
Guru:
  • Expert 192 Answers
  • Posted on May 15, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
192
Questions
Helped
64902
Points
457
There is not a master code to unlock the ipod- You will need to force restore the ipod to get it unlocked watch the video to learn how. This is your only option !
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
tip
Resetting an iPod if you forget your password
<p>The iPod is a security measure to prevent unauthorized access to your personal media player. Apple included an option to set a password to be used to unlock the device at startup. If you draw a blank password, you can still have the ability to unlock the device, but the process depends on the model of the iPod. IPod Touch owners to restore the device to a password reset code. Other iPod owners need only plug it into iTunes to lock the screen around. <br /> <p><br /> <p>Lock the iPod <br /> <p>1. Connect your iPod to your computer you normally sync your device. <br /> <p>2. ITunes load. <br /> <p><br /> <p>3. Click the "Eject" on the right to offer your iPod under "Devices" in the left column of iTunes. The iPod will be unlocked. <br /> <p><br /> <p>4. Select the "Extras" on the iPod. <br /> <p><br /> <p>5. Select "Lock screen". <br /> <p><br /> <p>6. Select 'Turn Off Screen Lock. " <br /> <p><br /> <p>Unlock iPod Touch <br /> <p>1. Connect your iPod Touch to your computer. <br /> <p><br /> <p>2. Open iTunes. <br /> <p><br /> <p>3. Click on the iPod Touch icon on the left "Devices" section column. <br /> <p><br /> <p>4. Select the "Summary" tab. <br /> <p><br /> <p>5. Click "Restore" and confirm the prompt action in the resulting pop-up. Follow the wizard prompts for the restore process to complete. <br />
on Jul 21, 2011 • Computers & Internet
tip
ITouch pass code forgotten?
If you cannot remember the pass-code or password to your new iTouch MP3 player first thing you can do to unlock the IPod is by doing the following: Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can do a Hard re-set. Hold down the screen lock button and the home button at the same time for 30 seconds. You will lose all your stuff (music, videos). You will then need to restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Then you can reset your pass-code and resync the data from the device (or restore from a backup). If you want to change the primary computer that your IPod is associated with, do this: A. Restore your iPod. WARNING: The restore process will erase all your music, videos etc and cannot be undone. All of your songs and files will be deleted. B. Connect your iPod to the computer that you want to be the primary computer. C. Open iTunes and synchronize.
Unlock
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
A1199 unlock code
My 5 year old sister was playing with my ipod and she locked it and forgot the pass word i tryed many diserant passes and now my ipod is disabled and says connect to itunes... but when i connect it to the...
Hi keekeerose20...
If you have forgotten the code, you can unlock the IPod by doing the following:
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please take time to rate me thumbs up.
Whenever i turn my itouch on it automatically says i need to plug it into itunes. It will not do anything but keep going to that, no matter how much i turn it on or off. So i plugged it into itunes, but...
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.If you want to change the primary computer that your iPod is associated with, do this:1. Restore your iPod. Warning: The restore process cannot be undone.All of your songs and files will be deleted. Always make a backup of your important data.2. Connect your iPod to the computer that you want to be the primary computer.3. Open iTunes and synchronize.
I have a 2gb ipod nanao that i own but a coupledays ago i locked it by accident and it was given to me by a friend that forgot the password to so i need an unlock for the ipod
I think you are talking about the 4 digit combination lock.
To unlock your ipod connect your it to the first computer it was synced with or the computer set as the primary one in iTunes. Open the iTunes application and let it recognise that your iPod is plugged in, then disconnect your iPod from the computer, and it should no longer be locked. Now reset the pass-code.
If this doesn't work you will have to restore your iPod to factory settings using iTunes, this will wipe all the music form the ipod but u will be able to put this back on later.
To do this open itunes and plug in your iPod then select your ipod and click restore. This process will take a few minutes and the iPod must remain connected at all times until it has finished. When done itunes will ask you to name your iPod and choose your syncing preferences.
I was looking through my ipod and went to security and accidently clicked screenlock and ever since i havent been able to unlock it
hello,
I’ve have solve a lot of people post questions on other posts here at MDV asking how to unlock the iPod Screen Lock function if you forget the 4 digit combination/pass code, so I figured I would write up a short tutorial here to direct you to unlock yours .
There are basically three ways to unlock the Screen Lock on your iPod:
  1. The most obvious and will not work for most people (or else you wouldn’t be visiting this web site). Simply enter the 4 digit combination/pass code at extras screen lock
  2. Connect your iPod to the first computer it was synced with or the computer set as the primary one in iTunes. Open the iTunes application, then disconnect your iPod from the computer, and it should no longer be locked.
  3. Use this final way only if the first two options do not work for you because it is a destructive process.
  4. please note this Everything on your iPod will be erased.
    This should not be a problem if you have all of your songs, videos, and other media stored in iTunes and you can synchronize once again after getting the iPod unlocked.
thank you and thanks for using fixya.
36helpful
6answers
How do I Unlock Ipod screen if I forgot the 4 digit password?
  1. The most obvious and will not work for most people (or else you wouldn’t be visiting this web site). Simply enter the 4 digit combination/pass code at Extras > Screen Lock.
    This should not be a problem if you have all of your songs, videos, and other media stored in iTunes and you can synchronize once again after getting the iPod unlocked. Besides, if you don’t unlock your iPod it’s useless right? Learn how to Restore your iPod using the instructions from Apple’s site.
If your iPod is simply frozen, follow my instructions for an iPod Lockup Reset.
or
I've tried the below method, and my music is still intact]
Step:
1. Plug in ipod.
2. Open “My Computer”
3. Look for the removable device (which is your ipod).
4. Open the folder, search for this hidden file : _locked.
rename or remove(delete) this file.
5. Eject your ipod.
Done.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
