1997 Buick Park Avenue Logo
Posted on May 15, 2010
Tach. drop's to zero while driving 70 ?
What would cause my 1997 buick park ave tachometer to drop down to zero when driving speeds of 50 mph or so ? I can feel car bogging out ,losing power then tach. drops to zero car will almost stall but has never actually died ,if i hold foot steady on gas it keeps losing power if i step on gas it feels like something was cloged and broke through as i pick up speed It feels like it go's into passing gear and runs fine for a while , but the tach won't kick back on intill I turn car off and on again ,
we;ve changed the fuel filter &oil filter so we know it's not that ,the service engine light was on and when it started losing power the ck engine light went haywire blinking & beeping ,i do need a tune up , but would that cause the tach. to drop to zero ? my husband power washed the engine could that of loosen anything that would of caused that to happen , Thankyou ,
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1058
Points
I have had the almost same problem twice. A 'thump', like the engine missed a fire and tach drops. Seems OK after restart. Electrical? Timing chain slip?
Has 135,000 mile. Any clues?
2answers
This engine has a surge; AT 35-45mph,it's a bit more prounounced, not as bad, but still there at 60mph. As the tach goes up some, then down, so does the motor, up then back down, etc.Any ideas?
About 73,200 results (0.82 seconds) Search Results
    Surging While Driving Between 40 and 50 MPH : Chrysler ...
    repairpal.com > Problems > Chrysler > Town & Country
    Around 35 mph (common street speeds) the engine will sometimes surge with noticeable tach fluctuations. ... I have a surge when coasting around 40-45 mph.
    Enginge surges RPMS drop while driving [Archive] - Chevy ...
    forums.trailvoy.com > ... > OEM Issues
    Mar 17, 2012 - 19 posts - ‎7 authors
    [Archive] Enginge surges RPMS drop while driving OEM Issues. ... I so hope somebody has a clue as to what is causing my '02 Envoy's (182k) engine to ... I'll be driving and when I get up to around 35 - 45 MPH sometimes my ...
    Hesitation and bucking on acceleration - F150online Forums
    www.f150online.com/...engines/476391-hesitation-bucking-acceleration....
1helpful
2002 Pontiac Montana trans problem
no I don't think so , it is only the torque converter clutch engaging and disengaging due to engine load. if you want to test this. go on steady speed over 50 mph no gas pedal movement. touch lightly the brake pedal but not braking and release . during this see the rpm drop down and raise
hope it helps
2helpful
97 Buick Park Ave, Non-Ultra. Brakes are slightly squeaking. Mechanic says that I have 50% wear(still good brakes). Will brake cleaner help? What is the BEST brand. OR do I need the brakes...
Disc brakes have a tendency to do this as they are usually a semi-metallic composition. They built up a "glaze" over time and that causes the squealing. You can take them off and sand off the glaze but it will come back.
Try this... Go out in an open parking lot with no cars around and drive at 35-40 mph then brake hard. Do this a couple of times and it will TEMPORARILY remove the glaze.
Next time you buy new brakes ask for a non-metallic composition brake...
Tachometer drops
What year is the vehicle ? The tach gauge probably is going out . GM has had insturment cluster gauge problem's . Faulty stepper motors .
Tachometer on 2001 buick park avenue stopped working
You most likely just need the tach repaired, they do fail. There is a company called Speedotach that repairs these as well as others, just google it
The brake light came on and brake pressure went to zero
warning light activates when it senses low fluid lvls. chk your brake fluid then chk for leaks.
I have a 1991 buick park ave ultra
your car is suffering from a faulty speed sensor. it works by using a signal generator in the transmission that creates an electrical signal in relationship to vehicle speed. This information is processed by the vehicle’s computer for engine and transmission management and provides the signal for the body computer that controls the speedometer. If the speed sensor itself fails then this might be the reason behind your problems. in addition, another cause of this may be that harness my be loose connecting to the transmission or behind the speedometer. there are multiple pins connecting behind the speedometer, and sometimes when one of those pins are not properly connected it gives a problem like yours.
Top Buick Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
