Printer is not found while making a connection wirelessly
You will notice that there is your IP address is showing but it doesn't mean that the printer is connected to the network. You need to make sure that your printer is ..find more on....http://technical-support-squad.blogspot.in/2012/05/wireless-printer-not-detectedfound.html
Get the IP address of the printer by going into Setup>Network>View Network Settings>Display Wireless Summary. Install with the HP installer and use a usb cable connection to complete installer. Then co into Printers and Faxes on the control panel, right click the printer and choose properties, check the ports tab and choose to add a new TCP/IP port and use the IP obtained earlier.
SOURCE: connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
SOURCE: Wireless Printer will not print wireless or connected
do you have the program disc if you do then inset it to the computer and hit restart installation and then follow the steps but make your you know your router name (SSID) first.
1) Install the network adapter on the printer, if necessary. Many wireless printers have the adapter pre-installed, but if this isn't the case, turn off and unplug the printer. Then, remove the back cover on the adapter slot and place the adapter into the slot.
2) Plug in and turn on the printer. Then, insert the drivers CD that came with the printer into the CD drive of the computer. If you've misplaced the CD, the drivers can be downloaded from the website of the printer's manufacturer.
3) Configure the network adapter. Once the drivers installation has loaded, select "Using a wireless network" and then select "Next". Usually, there is a User Agreement at this point, to which you will agree and press "Next".
4) Connect the laptop to the printer using a USB cable. Connect one end into the USB port on the back of the printer and the other end to a free USB port on the computer.
5) Finish configuring the network adapter. After connecting the laptop and printer with the USB cable, select "Create or modify the printer's wireless settings" and then click "Next".
6) Connect the printer to a wireless network. The wireless setup utility will automatically open after the adapter has been configured. Find your wireless network in the "Wireless networks found in your area" and select "Next". Then verify this information on the next screen.
7) Connect the laptop to the printer through the wireless network. Now, disconnect the USB cable. Make sure that both the laptop and printer are connected to your network. If they are, you're now set up.
I have the same problem. I have shut down the MS firewall and set up a new ad-hoc profile following the steps in the manual. When I try to set up the pronter, the new ad-hoc profile name appears in the list of wireless networks, but once I have selected this I get an error message saying it "cannot connect". I tried moving the printer and computer to within a few feet of each other but it didn't make any difference. I would be grateful for some advice.
