Car Audio & Video Logo
A
Anonymous Posted on May 13, 2010
How to connect rca plugs on metra 70-5510 what color is for what speaker colors are purple green white and gray thanks
Anonymous
Level 3:
  • Master 2,317 Answers
  • Posted on May 15, 2010
Anonymous
Master
Level 3:
Answers
2317
Questions
Helped
788125
Points
7079
White RCA is for left input/output and red is for right input/output. The purple wires are for the rear right speaker, the green are for the left rear, the white are for the front left and the gray are for the right front.
Need to know from top left to bottom right what each wire goes to on power plug on jensen car stereo model vm9311
Hi Jeff, Thanks for the question. When wiring an aftermarket car stereo I always recommend purchasing a wiring harness that will connect into the vehicles existing harness, Then you only have to worry about connecting each wire to it's color coded counterpart. With that being said, if you do not have the stock harness I can explain the wiring colors to the best of my memory
Red = 12v Memory power
Yellow = 12v Constant power
Black = Ground
Blue/white = Power Amplifier
Blue = Power antenna
Grey = RF speaker (+)
Grey/Black = RF speaker (-)
White = LF speaker (+)
White/Black = LF speaker (-)
Purple = RR speaker (+)
Purple/Black RR speaker (-)
Green = LR speaker (+)
Green/Black = LR speaker (-)
Sometimes there is a dimmer wire also, usually orange or pink I believe
I hope this helps, & Thanks again!
1helpful
Carradio pioneer DEH-171 i want to connect the wires for the speakers & found 4 different colors ... white, grey, green & purple & i suppose that the wires with black stripe are the ground....
white is left front
grey is right front
green is left rear
purple is right rear
blue is power antenna(if available)
blue with with stripe is amplifier remote(should have one if there are RCA connectors on the unit)
black is GND(ground)
yes you are correct. the stripes on the speaker cables are the GND
dreamsystems.
Got this amp from a friend and want to wire it up to my Sony head unit. The HU does have pre-out in RCA plugs. please help. I have tried it with: RED - stereo Amp Rem In YELLOW - 12V BLACK - -12V...
Senshin,
Red- 12 volts switched (ignition)
Yellow- 12 volts constant
Black- Ground
Blue/white stripe- remote amp turn on/ power antenna
If you have any orange wires there for the Illumination dimmer. (head unit dims when you turn the lights on). The white and gray are front speakers and purple and green are for the rear, solid being + and black striped being -. (gray and purple are right channels)Make sure that the RCA plugs go to the input side of the amp. I hope this helps, Ray
1helpful
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
3helpful
2answers
I need the wire color code for the clarion db225 ,so i can install it .
Red = switched 12V
Yellow = constant 12V
Black = ground
Blue/White = power antenna
Speakers are a color set, one with a black stripe
White set = left front
Gray set = right front
Green set = left rear
Purple set = right rear
The RCA plugs are pre-amp out.
5helpful
Wiring my pioneer deh -p2000 to my speekers
Check the back of your receiver, to see the plug with a set of 8 wires that should have the following color standard:
Left front: White
Right Front: Grey
Left Rear: Green
Right Rear: Purple
Note: 1) Colored wires with a line/stripe on it is NEGATIVE, thus connect to negative on speaker. When connected, speaker cone should vibrate OUT, not inwards, otherwise reverse speaker connection;
2) You can check to see if speakers are in the right order by 'panning' balance and fader controls (from left front only to right front only, to right rear only, to left rear only in succession)
3)If there is an amplifier in your setup, the RCA plugs (like home audio plugs, should be connected instead, NEVER both!)
Hope this helps
Mark
3helpful
Need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
2helpful
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
2helpful
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
2helpful
2answers
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
