My camera keeps saying card is locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SOURCE: Memory card locked
you have to put a bit of tape around the bit were the little tab use to be.. This works epically if you have lost the tab from the card.
p.s. i did this with an SD card an it worked i don't know if it will work with any other types of card. good luck anywhos, try yahoo answers they seem to have alot of info too. (Y)
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
There is a tiny button on the side of the card - so small you can hardly see it. Just slide it up and voila All is solved.
It is frustrating as there is nothing in the manual bout this and the onl line assistance wants to charge for 20 seconds advice Mine is free dorothy
SOURCE: Card Locked
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
SOURCE: Memory Card locked: I changed the memory card in
if we are talking about an SD card ...see that in a side ..the card has a slide like button with 2 positions ...locked and unlocked... just unlock it cause it might have been locked when handling it...
