Question about Dell 1700n Laser Printer
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly even when printing configuration pages. What else can be checked? I have placed other cartridges in this unit and the results are the same: faint print....
    Novelist:
  • 217 Answers
This could be the laser unit 'window' being dirty, or contaminated with toner.
Posted on May 17, 2010
SOURCE:
Printer problem
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. We need to reset this now!
4.Open the front cover of the printer
5.Press and hold down Go button for about 4 seconds until all the LEDs light up.
6.Once all 4 LEDs are lit, release the Go button
7.Close the front cover.
8.Your drum is now reset.
Jul 18, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
ON MY DELL 1700 PRINTER THERE ARE BLACK SMUDGES ON THE RIGHT HAND SIDE ONLY ON THE COPY PAPER WHEN IT PRINTS BOUT 3 INCHES APART?
Normally this is caused by the drum cartridge that fits under the toner. Replacing this drum cartridge will clear up the black marks on your print. Use this Dell Part# : A0373010 to order. After replacing the drum cartridge counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in order.
3. Then close the front cover.
This will reset the drum counter.
Jul 21, 2010 | Dell 1700n Laser Printer
Dell 1700 is giving me an error about the Toner. It also prints out a page telling me to replace the photoconductor kit. I have replaced the photoconductor and the toner but it still has the same error and...
The printer has no way of knnowing that you have changed the Photoconductor Unit, unless you tell it (as there is not chip on the Photoconductor).
The Photconductor reset procedure is as follows.
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
Apr 08, 2010 | Dell 1700n Laser Printer
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly...
Have you checked the fuser?
A laser printer fuser assembly is the heating roller unit that melts and fuses the toner onto the paper. The fuser assembly is made up of a heating roller and a pressure roller.
The heating roller applies the heat to the toner on the printed page and the pressure roller presses and fuses the toner into the printed page. If it's bad and not heating properly, the print will be faint, which is what you describe. You may be able to remove and clean the fuser, but if the printer gets lots of use, it may just be worn out.
See this link for an idea of what it looks like and a price.
http://www.fastprinters.com/ProductDetails.asp?product_id=DELL-H4919
I do not work or represent this company, so shop around.
Mar 22, 2010 | Dell 1700n Laser Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
Dark background on Dell 1700 printing
Faulty (or wrongly) remanufactured cartridges can produce a 'background' to a print, which can be even across the page or have a mottled effect.
Do a printer self test page (press the arrow button).
put the old toner cartridge back in and do the same.
Does the background show with the old cartridge ?
If it does, its a drum unit problem, if not its a toner cartridge problem, and that should be under warranty if you've just replaced it.
Dec 06, 2008 | Dell 1700n Laser Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Thanks
Nov 07, 2008 | Dell 1700n Laser Printer
Drum has toner on it/Cleaning the drum
You will need to replace it, you can use a soft cloth and clean it off, but it will only come back after the next print.
May 20, 2008 | Dell 1700n Laser Printer
Dell 1700n printer
Print out about ten or more sheets and see if it clears up.
Jun 27, 2007 | Dell 1710n Laser Printer
Dell 1700n Laser Printer Logo
286 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
