Emachine EL1230-01 xp Home ver 3 Turns on - you see the microsoft on screen - green bar goes thru several times and then says no signal. If I select to see bootup on screen- the last line is partition2/system32/... Mup.sys then no signal comes on I unplugged and plugged monitor. Would appreciate all suggestions. Thanks
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
SOURCE: the power turns off automatically after several minters
Hi...there,
It's seems your backlight inverter it about to burnt out... 3 years old! It's time for a new inverter.
SOURCE: why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue. Check the screen on another computer. If it is doing the same thing, it is the monitor. If it doesn't, then you have a video card issue
SOURCE: ACER Al1916W goes blank in 3 seconds. It shows
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: display does not fill screen completely
ok right click anywhere on the screen go to the bottom and click properties now there will be a couple of tabs at the tom desktop screen saver you want settings raise your resolution to about 1200 x800 or higher i think native for that is the 1680x1240 this should fix your problem
