Refrigerators Logo
Posted on May 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My LG french door ice maker won't make ice.
First the ice melted then we reset the refer freezer ice maker but it won't make ice cubes. We were advised to turn it down to minus 6 and the refer on 37. Still no ice cubes.
PRIMOAPPLIAN
Level 3:
  • Master 401 Answers
  • Posted on May 15, 2010
PRIMOAPPLIAN
Master
Level 3:
Answers
401
Questions
0
Helped
106331
Points
1126
THE WATER LINE POSSABLY FROZE YOU MAY NEED TO REMOVE YOUR FOOD AND UNPLUG IT OVERNIGHT WITH THE DOORS OPEN.MAKE SURE TO WATCH FOR WATER ON THE FLOOR.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
2answers
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
1helpful
Ice maker not dropping ice
Need more info. Are there ice cubes in the storage section just behind the freezer door? You may have turned the ice-maker OFF. When your depress the ice flipper, does the motor run behind the door? The motor may be burned out or the ice cubes in the storage section are so melted together in a giant glob that the agitator cannot turn.Or, maybe someone turned OFF the water supply.
3answers
No water to icemaker, but through the door water is working. Ice maker itself is ok.
This is most likely cause because some part of the ice maker/distribution mechanism is broken. If at all possible, remove everything from the fridge and freezer and allow the freezer to thaw. If that is not possible, you could try and remove just the ice maker to thaw it or try and thaw it while it is still in the freezer. I hope this helps and have a nice day!
Pieces of white plastic in my crushed ice
check the ice maker,the base rots out where the water forms into ice cubes or check the tray and the auger to see if a part of it broke off and is grinding up with the ice cubes
1helpful
Lg french door ice cubes stuck to together. please advice what to be done?
if the ice cubes get stuck together its usually because the ice maker water solinoid is letting too much water in. could have a bade water valve.
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
2helpful
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Ice maker not making cubes
You may have ice built up in icemaker where the water goes into it.  You will have to remove the icemaker and to get the ice cleared out.  Once that's done, you should be ok.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
