Acer Aspire 5100 Notebook Logo
Posted on May 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Having problem shutting down. Computer freezes when process gets to Windows shutting down. have to use the power button to complete shut down. Help!!!
chandrakanth reddy
Level 2:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 68 Answers
  • Posted on May 15, 2010
chandrakanth reddy
Expert
Level 2:
New Friend:
Teacher:
Answers
68
Questions
Helped
28741
Points
159
If your are using xp - it seems that u had not install xp service pack2 &3 it will resolve this issue kindly download the sp2 & 3 for ure xp. after installing sp2 & 3 u r facing problem let me know.
New computer will not shut down
Try going to your power option in the control panel. Make sure that hibernate is disabled, change what power buttons do. Make sure when you press power button it is set to shut down. Choose when computer sleeps as never.
P8b75-mle will not shut down
Hit control alt delete and look and see how many running programs you, most of the time it is a background running program that locks up the shut down process. On average you should have only 60 to 70 programs running. Reduce these and your start ups and shut downs will be much quicker, there are third party software that can enable you to do this with ease, or you can search google .
2answers
My laptop does not shut down when i press the shut down tab it indicates shutting down but i have to actually press the power button to turn off
The buttons can be set to do what you want, so look in the control panel under power options, typically you want advanced options or words like change what the power buttons do.
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
5helpful
Hi, my hp compaq cn8230 has ceased! I cannot log in because the pointer will not respond even when I plug in a wired mouse. When I press the power button again I get the msg "windows is shutting...
Press and hold the power button for 5-10 seconds and this should shut down the computer. If not, you may want to switch the power supply on the back of the computer to off to shut the computer down.
Regards,
G33k
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
Computer Shut Down Problem
Is the computer taking forever to shutdown in the blue screen or is it something else. Perhaps try closing the applications running with the system to help the process speed up and actually work without the usage of the power button.
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
How do i shut down my think pad? it will not cut off
In your case,
the most simplest way to shut down your laptop is to override your processing by simply holding down the shutdown button until your computer turns off (do this when all your work is saved and the "Windows is shutting down" mode is on your screen).
This idea is not recommended but will always work.
Hope I helped
- donman92
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
