Kenmore Elite Oasis 27052 Top Load Washer Logo
Posted on May 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cold water does not fill tub
When I want to do a cold water wash, the cold water starts, then auto lock engages. I then get a humming sound with no water going into tub. Warm water and hot water work fine. I checked pipes and they are fully engaged
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on May 15, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10844276
Points
101584
5helpful
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Water comes up to tub but doesn't fill the tub. Help and when I pull the knob I hear a humming noise
Hi and welcome to FixYa, I am Kelly.
The humming noise your hearing is the inlet water valve solenoid. Before proceeding try switching between warm cold and hot to see if any of those selections give you water. If you get water on either hot or cold then you probably have debris in the inlet screens of the water valve where the hoses connect. Turn off the water. remove BOTH hoses noting hot and cold installed positions and the use a thin knife blade on the outer edge of the screens to lift the inlet screens out of the water valve body. Wash then under slowly running water rubbing them between your fingers. Reinstall the screens. Connect the hoses in their original positions, turn on the water and test your water fill again switching between warm, hot and cold. This should get you going. If your still having problems after doing the above; please respond with MODEL: number and I will help you.
Thanks for choosing FixYa,
Kelly
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
NO WATER OR SPARADIC WATER
Hi, Does the cold water valve hum when you start the washer? Put settings on cold and start washer. If the valve hums, remove the hose and check to see if there is sand or rust plugging the screen (DO NOT remove the screen) Just scrap it or flush it with the cold water hose. If the valve does not hum, you will need to change the mixer iblet valve. Please let me know if I can assist you further or order you the part you need.
Thanks
Vic
1helpful
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
3helpful
2answers
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
2helpful
2answers
Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting FIXYA.com
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Alexander
vince
