After about an hour of being on my 47 inch Vizio starts to flicker between full color and grey or black and white. IT IS not the TV stations. It does this no matter what you are on if its Tv or A/V or if its on Component One or two. I played Wii on it last night and it did it while playing Wii. I have called Vizio Tech and did what they told me and it did not fix the problem. Help Me please.
SOURCE: "flickering" of tv
does the VIDEO FLICKER and the screen stay lit? Then it's the Video board, but if it Blacks out it's the Inverter if it's an LCD and the Ysus if it's a Plasma...
You still have to send it to Vizio to get it fixed
SOURCE: My 47 in visio is flickering between black and
usually due to poor signal strength or loose connection.
Please rate my help++++Thanks for using FIXY
SOURCE: flickering white line across top of vizio 47
I had that problem on my Vizio 37" and my new Vizio 55" and now after reading the solution of adjusting the HV position in the setup menu, the problem is fixed! Thank you!!
SOURCE: I've owned a Vizio VT420M for just over 13 months.
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
