Maytag Neptune MAH5500B Front Load Washer Logo
Posted on May 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My front load washer "walks across the tile floor", it is level, what can I do
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on May 14, 2010
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2971301
Points
24702
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
1helpful
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
1helpful
Vibrates then starts walking across floor
LG washing machines are very finicky with being leveled, they must be 100% level, and squared up on all sides. Be sure to lock the nuts in place, once you level it, to where it needs to be. They are also finicky with certain floor surfaces, more leveling may be required.
2answers
Washing machine walks
The problem MAY be fixed. I went to http://www.fixya.com/support/t14304-washing_machine_walks_across_floor , made sure shipping bolts were out, then discovered nuts that clamp the feet were loose. They are now tight with unit re-leveled. Testing is in progress.
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
2answers
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
