Question about Whirlpool Safety Bath Walk In Bathtub - Stretch Without
12 year old fiberglass tub originally white, now
12 year old fiberglass tub originally white now yellow everywhere the sun has hit it. How to restore color?
    New Friend:
  • 190 Answers
Home depot sell a bath tub remodelation kit.
it cost about $40 .
Posted on May 19, 2010
2 Suggested Answers
SOURCE:
Phantomgreen
  • 128 Answers
SOURCE: 12 year old fiberglass tub originally white, now
You can't.You will have to wet sand and gel coat it.I would hire a pro painter to come in and do this.
Posted on Mar 21, 2010
The casing around the jet on the tub side is cracked and is causing water to leak on the outside of the tub. This has happened to three of the 10 jets. What can I do to fix this?
Cheap plastic fatigues with heat . Silicone will work but will not keep the crack from continuing. The fix depends upon what type of plastic you have . It is likely a polyester like fiberglass in which case you can use regular fiberglass to fixit . Rough up the outside with 80 grit , brush in fiberglass resin ( don't forget to mix in hardener) lay in glass material , repeat until built up . Repair the front with a good "gelcoat " repair kit which allows you to mix match color.. sand with 220 , then 600, then 800, then 1500, then 3000 , polish with automotive whit polishing compound , wax
Nov 14, 2017 | Jacuzzi Home
What is the best way to remove oxidation from a fiberglass kayak. The color is very faded from years of direct sun exposure. Kayak is >15years old. I want to restore the original color and luster.
My kayak was nearly 30 years old & exposed to the elements all the time. To clean it up, I washed it down with the Amway Car Wash & polished with the Amway Silcon Glaze car polish.
The kayak came up beautifully & I'm still using it today
May 10, 2010 | Boating
12 year old fiberglass tub originally white, now yellow everywhere the sun has hit it. How to restore color?
Mar 21, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
There is really no easy way short of sanding lightly and repainting. (I am told that "tremclad" paint intended for exterior use on metal in tough situations is good for this kind of thing.)
Wax (car wax or wax for fibreglass boats--which is often available in colour) will work for the short term.
Mar 17, 2010 | Boating
Patch for tiny holes in fiberglass tub (8 yrs. old)
From my own experience I had a crack in mine. I sanded the area I wanted to patch. I bought a fiberglass repair kit from the hardware store. I mixed the hardener with the resin and applied it without the cloth. Make sure you have good ventilation and don't get it on your hands. After it dried I sanded it smooth it didn't look the best so I hit with a little spray paint. I have since replaced the tub but it held until I was ready to do that. A couple of years. Hey if this helps give me a vote please.
Mar 03, 2010 | Home
Cast-iorn tub to fiberglass shower kit not sealing
keep caulking or change to ceramic tile, or one piece shower units ,without seams
Mar 03, 2010 | Home
Blue/Yellow Splotches on screen
It will be 12 appliance years old in October. Not much justification for trying to repair it.
Mar 23, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
Bathtub refinishing
epoxy paint with pressure gun but you got to prepaire the surface it change with the paint produit foolow instruction but it not as solid as the original
THANKS FOR USING FIXYA
PIERRE
Feb 17, 2008 | Office Equipment & Supplies
Whirlpool Safety Bath Walk In Bathtub - Stretch Without Logo
275 people viewed this question
Top Whirlpool Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
