yes we did that already. i have even tried putting a rubber mat under the washer and i have even used the leveler to see if the floor is even. its a brand new home and the connections are upstairs and im assuming the floor is even.yes we did that already. i have even tried putting a rubber mat under the washer and i have even used the leveler to see if the floor is even. its a brand new home and the connections are upstairs and im assuming the floor is even.
You can't post conmments that contain an email address.
first off what's the brand name and model number?if it's not a metal sound like the frame vibrating check the blower wheel,as soon as the motor starts to spin so does the blower wheel,but that could be alot of things depending on the model you have.
If it brand new I would call back the service man or store I bought it from..From what your saying..it either has a powerful motor or the drum is out of balance with out any cloths in it....Put it in spin mode with nothing in it...If you get vibrations its one of two things...Either the whole washer isn't leveled correctly or its a unbalanced washer drum...Call them back and tell them either they come out to check it or you want it replaced....Be firm...It'd your money
Check to make sure it's level. Number one cause of vibration is not being level. Number two cause is soft floor and what I call "Sympathetic vibration" where the floor shakes a bit and it seems like it's in time with the vibration on the washer. It then magnifies the vibration and makes it worse.
If it's level and on a solid floor, you need to get it serviced under warrenty.
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
make sure you have all the shipping material out of unit..4 bolts in back and styrofoam under tub if so ,then get a adjustable wrench ,,,put unit in drain spin cycle or spin cycle only..when unit gets to fastest spin ,,thats will come when its about 8 minutes left..tighten each leg lock nut on unit until unit stops vibrating..only turn the lock nut not the leg..only adjust lock nut on legs in high speed spin
Yes. Did you buy this new or used. ????? Please le me know. I have seen the gromot on these wear out quickly. You need to get it repai if under warrenty .
