Samsung YP-Q1JEB/XEU  Digital Media Player Logo
A
Anonymous Posted on May 12, 2010
I need a driver for my YP-Q1/JEB all the sites want to charge me a lot for scanning my computer and supplying the drive can you tell me where I can download just the appropriate driver?
Curtis Sewell
Level 3:
  • Samsung Master 7,482 Answers
  • Posted on May 14, 2010
Curtis Sewell
Samsung Master
Level 3:
Answers
7482
Questions
Helped
1941341
Points
24946
All the folders in my samsung i-pod YP-Q1 have become shortcuts that refer to 'uIaU3k3kzmh4Otjy73o.exe' and does not open
Propabely it is a surface disk problem which damaged your files or a virus could do so,try to open the folder by right click and choose open, if it is the same problem then it must be a virus and you have to reformat it, sorry for that . You have to scan your pc also for malware, viruses.
My pc does not detect my samsung yp-t10 but it charges.whats the problem?
i have a Samsung YP-Q1 with the same problem. i soon found out that the data cable was damaged. maybe yours is too. check.
2helpful
How cab i instol viedo file in Samsung YP-Q1 mp3 player
Go here (http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=YP-Q1JEB) and download the multi media studios for video conversion and the manual Hope this site works for you please rate....Joe
2answers
I have yp-q1 with same problem
probibally a software bug, simply go to the samsung website and instll the latest firmware version and upgrade it.
1helpful
I can't update my firmware on my yp-q1. it says
Don`t try to use Emodio.  It will just not do it.  Go on the Samsung site, under support type in your model and download the latest firmware.  Also download the upgrade guide (PDF).  It is very simple.  I did it and got my Q1 upgraded to 1.34 US.  ( as they say you will have to restart it twic.
Have fun.
Michel
23helpful
5answers
Samsung YPQ1
I had the exact same problem with my Windows XP when trying to interface with my new Samsung YP-Q1 16GB. Hey, it took a bit of Forum searching but it can be done.
Load your Emodio software from the supplied CD.
Download Windows Media Player 10 or above (important)
Plug in your MP3 Player to USB port (hopefully your USB ports are USB2.0 otherwise you'll need to see if you can upgrade their drivers to make them USB2)
If, as with mine, its still not appearing as a portable device in Windows Media Player or EMODIO
then
Go to Control Panel. (I prefer Classic view where you can immediately see Add Hardware Wizard)
Run Add Hardware Wizard. searches for new Hardware. Prompts for is Hardware connected?)
Look at list of devices Q1 should appear as yellow Q1?
Highlight Q1 and continue.
Prompted for dowload of MTP file.
Install file.
Hey presto....
Worked for me anyway although Emodio software still had problems writing to Q1, Windows Media Player had no such problem.
4helpful
Doesn't show as a driver
I did it!...
you have to perform all the windows updates, then you have to install "Windows media player 10" (I have installed "Windows media player 11" because on my pc the wmp10 didn't work...).
it seems that YP-Q1 work with some driver hidden in wmp10 or 11...I didn't found them nowhere...
connect the mp3 with the cable usb and test to automatically install the drive... it should work... I did it after a few hours...
sorry for my dumb-english, I must improve it ;)
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
