When soud + pressed once it increases on its own until 100 reached
When sound - pressed it dcreases on its own to zero
When input is pressed it keeps cycling through all the choices and will not stop
off/on does not seem to work much of the time
The TV can be controlled using the consol buttons however
SOURCE: Need instructions to program DVD Rec.Remote
Get the manual or figure out from LG's website about the thing,the site should have a download of the manual for the thing
SOURCE: time warner cable, LG TV. volume control
if they are the only buttons that do not work i would say the pcb needs to be cleaned
SOURCE: I have LG 42LG30 15 months old the remote control
The rubber keys are moulded as protrusions from a rubberised membrane which is slightly permeable to sweat and grease. Over time this builds up as a corrosive yellow greasy deposit on the reverse side of the membrane which prevents keys from making good contact with the circuit board behind. The process occurs far more quickly if you regularly operate the remote with greasy hands such as is the case if you regularly eat in front of the tv, or if you (or any other user) frequently use hand moisturiser.
There are only two repair options:-
1. Take apart the remote and thoroughly degrease it. The membrane itself can be washed in soapy water but dry it thoroughly before refitting. At best this is only ever a temporary fix.
2. The official fix (and best) is to replace the remote.
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
