Attempting to connect wireless router to a wired router... followed all steps, but orange light on front of the wireless router blinking on the WLAN port.
Once all cables are connected properly, my PC will not recognize the wireless router and i cannot stay connected to the internet.
please help, it is greatly appreciated.
Wi-Fi base station: Understanding and resolving a blinking amber status light
Your Wi-Fi base station status light blinks amber.
Here are some of the more common reasons that the status light may blink amber:
A persistent, blinking, amber status light indicates that your Wi-Fi base station may require your attention.
How to resolve a blinking amber status light alert
Launch AirPort Utility to determine why your Wi-Fi base station status light is blinking amber.
Apple recommends that you use AirPort Utility 5.5.2 for Mac, AirPort Utility 5.5.2 for Windows, or a newer version of AirPort Utility if one is available.
Do not use any version of AirPort Utility earlier than 5.0.
In Mac OS X, AirPort Utility is located in the Applications > Utilities folder.
In Microsoft Windows, AirPort Utility can be located by clicking Start > All Programs > AirPort.
Note: You may also locate and download the latest Wi-Fi base station firmware and software by clicking here.
Important: You must reset the Wi-Fi base station using the reset switch to re-enable checking for the conditions you ignored.
Eliminating the blinking, amber status light may require making changes to a specific setting, or putting a checkmark in the "Ignore" checkbox beside any option you don't wish to change. A checkmark simply tells the AirPort that you are aware of the issue and you have chosen to ignore it. For example, you may wish to leave your AirPort open without a password so that anyone can join your wireless network.
SOURCE: Random Disconnection and WLan indicator lights
Saw this on another post for this router: "in the DHCP configuration on LAN menu. the lease time was set to 72 hours (3 days) i change it to 720 hours, cos that was the most it would allow... so hopefully that would fix it. " maybe you're having the same problem. another usefull thing to do is to update the firmware from the D-link site. some stability issues such as this should be fixed by a firmware update. post what happened goo luck ;]
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
