Nintendo Pokemon Diamond for DS Logo
A
Anonymous Posted on May 11, 2010
Had to format memory card what do i need to run r4 and memorycard
Had to format memory card what do i need to run r4 and memory card keeps saying cant find ds menu dat this only happens with r4 chip normal games work fine. Any help please??
phil
Level 2:
  • Expert 567 Answers
  • Posted on Jun 28, 2010
phil
Expert
Level 2:
Answers
567
Questions
5
Helped
244661
Points
948
Download latest firmware nds-gear.co.uk
2answers
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Hi i have a fujifilm finepix S1 pro, was working yesterday, today came to putting memory card in and it wouldnt work 'card not initialised', tried formatting the card on the pc a few times didnt...
1. You should always format memorycards for cameras IN the camera itself.
2. Try another memorycard and check if all is working fine.
3. If you get the same problem, check if the memorycard is well seated into your
camera. If so, your camera may need service.
Jun 28, 2011 • Cameras
You will need to download and reinstall the R4 firmware.
After downloading and decompressing the new updated files, there will be one shell folder and two files _DS_MENU.DAT, and _DS_MSHL.NDS.Copy these files to the root directory of TF card to replace the former files (ex. F:\ or E:\).
You can download the update files and firmware here:
http://www.r4ds.me/download/r4ds.html
1helpful
Black Screen with : Loading... on it
Get the memory card out of your R4 adaptor, putt it into a card reader.
Connect the card reader to your pc and goto Start/run.
Run this command: chkdsk /x /f /r x:
Putt for "x:" the drive letter where your card reader is at.
If the file system is repaired download the newest R4 Kernel and unpack it to your memory card, use 7zip, this software is free
and handles zip and rar files + many other types.
R4 Kernel:
http://download.r4ds.cn/english/English-1.18.rar
7Zip:
http://www.7-zip.org/
Use safe removal to disconnect your card reader, so that the file system at the memory
card wont get damaged.
If this wont work, you'll have to format your memory card using fat32 and unpack afterwards
the kernel files to the memory card.
To format goto start/run and use this command: Format x:
"x:" Is again the drive letter where your card reader is at.
Succes.
6helpful
4answers
Troubleshooting R4i Gold Card for DSi
Hi I was having the same problem but now I have fixed it. My dsi is running version 1.4 and I have a R4i GOLDwhich is now running 1.54 with the r4i update that I got from this web site.
http://dsdatabase.org/blog/2009/08/14dsifirmware/
You need to load them onto your memory card and then put it in a ds or ds lite and run the update. Hope it helps its worked for me 5 times so far on different r4i gold cards.
4helpful
2answers
Not working
you have to format ur SD card and download the software from the original R4 website, nowhere else, it'll work then!
Hi there can any 1 help i have a r4 card installed the program and games but nds keeps on saying no ds card inserted is it faulty thanx
hi
first of all , check your r4 version.
there are many.
have you put the right firmware on your r4?
original : http://r4ds.cn/download/r4_v1.18_kernel.html
r4 revolution pro : http://www.r4dspro.com/download_en.html
r4 ultra and de luxe : http://www.r4deluxe.com/en/down.asp
r4 III : http://www.r4dsl.net/download-en.asp
after that it should work.
or maybe you should format your memory card first.
1helpful
2answers
Insert the R4DS in the DS lite and it just says "loading" and thats it ?
hi
there are many.
(or maybe you should format your memory card first.)
My memorycard is locked how do i open it
hi debbie;
have you tried formatting your memory card from your camera menu? i havent seen a memory card without lock pin but you may try my advice. :)
1helpful
4answers
Corrupted memory card help!!!!!!!!!!
I believe you are out of luck. Note that memory cards that are not Nintendo brand, (like Mad Catz) tend to have this problem. Never buy a third party memory card for anything other than backup purposes.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
