LG WM-12230FB Front Load Washer Logo
Posted on Mar 29, 2008
Error Message CL in the front panel
After the power is switched on, we get an message CL and nothing can be done from thereon
  • glassbreaker May 04, 2008
    LG WD 10160FU. Shows CL on screen when powering up. Nothing else works. Cleared coin trap, found coin and elastic bands (child's!). Still no start.
  • neppydog Aug 17, 2008
    I have a Inverter WM-12230FB Mine also has the CL message and i cant find my book to see how to clear it I dont have any temp buttons to press as mine has a dial can anyone tell me how to clear it please.
glassbreaker
Level 1:
  • Contributor 1 Answer
  • Posted on May 04, 2008
glassbreaker
Contributor
Level 1:
Answers
Questions
0
Helped
2326
Points
5
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
aidin
Level 1:
  • Posted on Apr 06, 2008
aidin
Contributor
Level 1:
Answers
Questions
0
Helped
2326
Points
Danby DWC114BLSDD wine cooler temperature gets too Low giving error LO followed by CL and beeping
If the "HI", "LO" or "CL" error codes appear on the display for more than 5 minutes, a power reset may rectify the issue. Unplug the appliance, wait 5 minutes and then plug the unit back in. If the error code persists after a power reset, contact consumer care or an authorized service agent
Aug 13, 2021 • Furniture
1helpful
3answers
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Canon pixma mx892 front door flap broke - was printing but now I get lots of clicking noises and then a message telling me to power off. The rear paper tray does work but lots of clicking.
What's the error message? Did it give you an error number?
My first thought: That printer detects if the front door is fully open, and if it's not, it gives you an error message and makes you turn it off and on. So look at the hinges where the door was connected and see if you can see the switch that tells the printer whether the door is open. Then figure out how to move that switch to the "open" position.
I hate that front door.
3answers
We have a no-cl message after we rang up a customer and hit a key. Now the cash register is frozen with an no-cl message. The cash register is a towa fx-400 and my ser id is #2054743
I've searched online for any similar problems and it seems that there's not a lot on the net for a CL error. Most were printer related.
Just by seing things from a logical perspective, this error may be a tray issue, so try opening and closing the cash tray and see if this remedies the problem. If you can unplug the register from the power cord, do so and see if this helps. Try the unplugging with a closed and an opened tray.
I'm not a cash register expert so this is just guesswork. Hope it helps.
4helpful
CL error message
That means that your washing machines child lock is on. You can find two buttons Temp and Options in the panel. Turn the machine on, press these two buttons together for 3 seconds and thats should be it.
C module causes error message: "Error spawning cl.exe".
I'm guessing C Linker is the executable we want to bring in to make FORTRAN and C be friends; maybe you're missing an include line or environment declaration on the C or FORTRAN side to get it done (or better error messages!)
8helpful
3answers
Message CL has appeared whch is child lcok. How
hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
2helpful
2answers
Lg inverter frontloader washing machine wont turn on. screen say's CL??
CL is about the Child Lock which is done by pressing both the buttons together. To release the same do press both the buttons under the display simultaniously
8helpful
3answers
TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
3answers
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
