Behringer Eurolive B212A Speaker Logo
Posted on May 13, 2010
Have 2 Behringer Eurolive B 215 Speakers and the 15" woofer have no sound coming out only sound thats coming out is from the horns
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1035
Points
I had the same problem with one of mine. The problem was that the Main Coil Component on the board had come loose. I think it was never soldered in place. Just glued. I glued it back but now it keeps cutting out. I need to solder it but don't have the right equipment.
Anyway, I think its a manufacturing issue they have. The way I found out was. I took it apart and started lightly tapping on the electronic components while the speaker was engaged. When I hit the large coil the base came on. Then I turned it off and grabbed the coil and it fell off the board. It is fixable though.
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3465
Points
31
These have a crossover inside as well as a fuse. If it is blown the link is gone and only the horns will work.
Remove woofer from behringer B215A
you want a woofer replacement? ... it's possible but you need to put whole your speakersystem in a program and the change you get the values you want is slittleeee. No if you need to ask if you have to change.... noooooooo. It's to complicated and only can ve done by peoples with real knowledge....
Bass went out
The 15 inch woofer is blown and you are hearing only the tweeter horn. I would definitely check that speaker on something else though, because the amps inside will also blow fairly easy, and you can't get parts for these. I would salvage what you can and move on. If both speakers work alone, check connections and amp. If you find that the 15 does work, then make an unpowered monitor. Behringer does not give any referencing of any parts. They have all special part numbers that you can't crossreference to find replacements. This is a marketing strategy to eliminate others from repairing, so you will buy another one. They think they would sell more but it just turns musicians away from their junk. The only piece of behringer equipment worth using is the FCB1010 controller and nothing else.
3answers
I open my b212a and disconnected the speaker and horn wires and know i have completed my repair i am read to reconnect and i don't remember which set of wires are the positive side
Because the system is bi-amplified, it is important to replace the wires correctly to avoid phase problems. I don't know how the wires are colour coded, but if it is any help I downloaded the schematic and the wires are numbered 1: Woofer Active 2: Woofer Earth
3: Tweeter Earth and 4: Tweeter Active. Sorry if that's no help. Otherwise it should be easy to trace the wires to see which connect to earth.
2answers
Behringer monitor lost bass
You should check the woofer's impedance as a starting point, let me know further.
Behringer b415 horn stop working how and where i get replacement
First thing is to test the horn as the crossover circuit may be the problem. If you need the part(s) for the crossover you can get them via DIgiKey.com, however repalcing the horn driver you may have to go through FullCompass.com and if the part has to come from Behringer it takes months.
1helpful
Tar like adhesive has gone sticky round speaker cones and volume has droped
The tar like sticky substance is the suspension of the speaker cone and there is nothing wrong with that. Its doping compound applied by the speaker company to damp the speaker ( Was it not always there? ) If the suspension has come off the bass notes will flutter, if not its some other problem. Play some music and put your ears near the tweeters flared horn to see if they working. Nearly 30% of your sound comes from the upper part and if you have damaged it there will be a volume drop.
These speakers are quite complicated on the inside. It has two amplifiers, one for the woofer and one for the tweeter. It also has a digital sound processor. Any thing could be at fault, even a simple wrong setting.
I bought a Behringer Eurolive B1220 Pro speaker with my PA system brand new and it sounded great at first. Now it sounds really muddy (the other 2 speakers I bought work fine) almost as if the horn has...
Bad news...you've blown the tweeters. Overdriving the mixer/amp creates distortion on the amplifier which heats up the speaker voice coils and eventually causes damage. Because of their small diameter voice coil windings the tweeters fail first (opens up like a fuse element does) followed by the woofer making a scraping sound (deformed voice coil) or not working as well. Warranty service because you blew out the tweeters? Don't get your hopes up.
1. PLEASE use enough power for the venue that you have. A high powered system will run all night at 10:00 (physical volume knob setting) than an underpowered system set for 2:00.
2. Get speakers off the ground and closer to your audience's ears. Audio from speakers on the floor must battle surfaces that actually absorb some of the sound....carpet, drapes, etc. And besides, legs can't hear that well.
Solution for repair eletric solving behringer b212a
Can not give solution untill units are inspected. Call Pro Line Music 215-736-8055
1helpful
I have a set of Behringer B215 passive eurolive speakers rated at 600watts. Both speakers are not working but there is limited sound coming from the horn. I don't think its the speaker but more so...
Check the DC resistance of the speakers. I should not be over 10 ohms. If it is something, probably the speakers are blown.
That 600 Watts is peak and you should use an amp of say 300 Watts a side max to drive this for safety.
You may find a fuse inside, but not likely you would be so lucky... Also if the amplifier failed it could have sent DC current through the units and fried the voice coils of the woofers. The horns often have capacitive coupling and usually will survive.
You can fiond 15 inch replacement speakers on Ebay... HOWEVER get the dimensions as they often vary and may not fit.
Amp keeps blowing speakers
If the amp blew the speakers , it sounds like the amp pumped HIGH levels of DC voltage into the speakers.
Get another amp and not Behringer,not Pyle,not Gemsound and not Numark.
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
