To manually edit registry is kind of risky and inconvenience, so it is recommended to apply special designed professional error repair software to fix d3dx9_29.dll error completely. Just follow the below instruction:
* Step1: Free Download Award-Winning DLL Repair software.
* Step2: Install the software in your computer with ease.
* Step3: Click Scan button to diagnose dll error on your computer.
* Step4: Click Repair to fix dll error and other found PC errors in seconds.
There are quite a few different ways that d3dx9_29.dll errors may
show up on your PC. Some of the more common d3dx9_29.dll errors are
listed here:
D3dx9_29.dll errors usually appear when a software program, most often
a game, is started. Occasionally, d3dx9_29.dll errors will display
after a game is loaded but right before the game begins.
Unlike many other dll errors which can have complicated causes and
fixes, d3dx9_29.dll issues are caused in one way or another by a single
issue - some kind of problem with Microsoft DirectX.
The d3dx9_29.dll file is one of many files contained in the DirectX
software collection. Since DirectX is utilized by most Windows based
games and advanced graphics programs, d3dx9_29.dll errors usually show
up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
