Power Acoustik PTID-4003TV Car Video Player Logo
Posted on Mar 29, 2008
Power Acoustik PTID-4007
PTID-4007 can not get files on sd card to play. Once card is inserted the display shows that it has been inserted, and then it shows the screen saver and says close. after that it says no disc found and thats as far as it gets. can you please help me with this. thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Aug 07, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2042
Points
9
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
Dj Perssiss
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 08, 2013
Dj Perssiss
Contributor
Level 1:
New Friend:
Answers
Questions
6
Helped
1078
Points
21
So, do u mean I should not use any MP3 format files in my SD card?
A
Anonymous
Depends on what you are trying to get on mp4's and pics i know work mp3 wont play through a sd card only cd
Anonymous
Level 1:
  • Posted on Aug 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1078
Points
Mine does play MP3 on the SD card.
I'm having difficulty customizing my screensvaer. how would i be able to go about that? I have a PTID-7350nrbt
I have the PTID 7002 but im sure its the same solution, this is from Power Acoustik:
You need to have the remote in hand. Insert a memory stick or SD card that has the images you want to use. When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set of icons on the bottom. If you do not see an icon with a hand, press the arrows that are in a circle until you do. Once you see the hand, press it one time. It will save the image onto the internal memory. You will find the image in the screen tab in settings, under all the stock images.
How do I download pictures to my Power Acoustik PTID7002NR?
You can use a USB Flash drive or SD/MMC Card or an iPod to view files (Pictures,Videos,Music files..etc) in the player.Touch the icons [USB], [SD CARD], [IPOD] according to which device you are using.The corresponding modes are switched automatically by the player when it detects one of the above devices.The player will switch to [RADIO] mode automatically when the above devices are disconnected and if there is no Disc in the player or to the [DVD] mode if there is a Disc inserted.You can view the detailed description in the following link ( http://www.poweracoustik.com/pa2006/manual%20and%20catalog/source/PTID-7002NR.pdf ).Your valuable feedback would be appreciated.Good Luck.
I need a manual for a power acoustik ptid4007
i looked the manule for that is not posted on their home site sory but u may have to do without
2helpful
I HAVE A POWER ACOUSTIK PTID-8970NRBT MY PROBLEM MY SCREENSAVER
Here is what I received from Power Acoustik for screensaver and desktop saving from SD card. "You need to have the remote in hand. Insert a memory stick or SD card that has the images you want to use. When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set of icons on the bottom. If you do not see an icon with a hand, press the arrows that are in a circle until you do. Once you see the hand, press it one time. It will save the image onto the internal memory. You will find the image in the screen tab in settings, under all the stock images."
2answers
Sd card wont play
sometimes you have to format the songs and then put them on the sd card but if you allready did that your sd card might be junk and make sure the sd card you bought is for music some arent
2answers
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
