My optoma is projecting white spots onto the screen. They seem to just appear. Some have began by 'sparkling' for a while and then they stay white perminantly.
    Champion:
  • 269 Answers
If it is a DLP projector then the DMD on the engine is likely bad or the main board is bad. The white things are pixels.
Posted on May 18, 2010
  • Cwfbassman Aug 31, 2011
    How can we order this part
    Champion:
  • 225 Answers
There is a video covering this on youtube
Posted on Dec 07, 2012
  • gmontgome595
    gmontgome595 Oct 12, 2014
    Most projectors are very similar in construction. I reccomend you take lots of pictures if you attept the repair.
    New Friend:
How do i open up the optoma projector it doesnt have normal screws?! plus where do i find the dmd chip?pls help ......
Posted on Nov 13, 2011
  • Simon
    Simon Feb 24, 2013
    Hi there, It should have point 1 Phillip screws.
    Problem Solver:
  • 3 Answers
Its not a pixel problem,its dust inside on the mirror
Posted on Apr 18, 2011
  • 2 more comments
  • keithtoad Jun 26, 2011
    I have the same problem and after reading this Solution 2, I looked thru the lenz onto the mirror up close and can see the dust particles there. The problem is how to get to the mirror to clean it off. I just used compressed air but it did not help. I will have to tear into the unit I guess or pay $85, per hour for our local repair guy to do it. There are 4 screws to remove the top cover.
  • greene2andy Jun 28, 2011
    could be either or both. We had same problem, tore apart projector, cleaned all 3 prisms and every mirror... still had spots. looked like a starfield. removed dmd chip board from behind projection lens, starfield is on there. still trying to figure out how to replace w/o costing more than the projector is worth...
  • evilthoughts Aug 01, 2011
    i have the same problem - took apart projector, cleaned it, no use still starfield. Checked the lamp and saw tiny dots on the glass of the lamp; on the inside. Guessing new lamp would fix it i am going to buy one soon I'll write back.
  • gmontgome595
    gmontgome595 Nov 26, 2013
    once you get the chip number its not to hard to obtain for 200$
I also have these white spots on my sreen ep728 optoma projector I also believe I need a dmd chip . Im trying to figure out how to order this part and not pay over half the cost of the machine. optoma quoted me 500.99
Posted on Aug 31, 2011
    New Friend:
I had the very same problem, swapping the dmd chip made it like a new projector.
Posted on Feb 24, 2013
  • 138 Answers
You fully can write down your projector DMD chips models needed, perhaps someone have this parts, can help you to find cheap MD chips at the earlier time
Posted on Mar 10, 2012
6ya staff
SOURCE:
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
Hi, I have a projector Optoma EP7155 and it appear white and black spot like dead pixel, I would like to know where I can buy a DMD chip with the CCD and how much it will cost. Thank you
global projectors is one source. You need to find out from Optoma the chip you need or take apart the machine and look at it. From China they run about 200 bucks. I've only done Mitsubishi so far.
Dec 16, 2012 | Optoma EP7155 DLP Projector
There are white spots all over the projected screen - do I need to clean something or are they
No you have to change the DMD chip. It is mounted on the back of lens system.
Nov 02, 2012 | Optoma TX542 Projector
I have optoma pk301 pico proyector,suddenly a few white and dark spot have appeared
Its a bad DMD chip. Seems this is a common problem with the PK-301's sadly. Mine is out of warranty and a new chip runs about $180.
May 28, 2012 | Optoma PK301 Projector
I have a Optoma HD 67 projector and suddenly it has a lot of white spots on the screen, even if you remove the input cable the white spots stay there
as greg instruction, it is very detail,
usually, white dots problem is reason of the DMD. perhaps the manufcaturer can't directly and singly sell a parts for end user, they always let you send broken machine to their repair store, then ask for high repair cost.
actually, optoma HD67 projector with 1280*720 pixels, so i think you should buy a 1272-6038B DMD chips, if you need further help, please freely contact me again,
Jul 28, 2011 | Optoma Office Equipment & Supplies
I have optoma pk301 pico projector. suddenly few white spots have appeared on screen which do not go away
Hello, I have the same problem with a pico 201, and can not solve it, I can not contact optoma support team
Jul 27, 2011 | Optoma PK201 PICO Pocket Projector...
Hi i am having problems with the projector it was going well for the last year that i have it but up to a week ago i have been getting tiny white dots appearing on the screen from the projector. i have...
I noticed you have a DLP projector. I have a Optoma EzPro 756 which is also a DLP projector.
I notice white "blobs" on the screen when there is a black screen. It is caused by dust getting into the optical block not the lense. If you are comfortable with opening up the projector, you could gently blow out the optical area with compressed air, GENTLY so you don't dislodge any components, and see if that helps. I seems to be a common problem with DLP projectors a few years old. If there are sharp focused dots on the screen then most likely, it could be some pixels starting to go bad like dead pixels on a computer screen. That problem is pretty much irreversible.
Hope this helps,
Feb 20, 2011 | Acer X 1130 3D DLP Projector
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Aug 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Light spots
broken colour wheel is what the problem is.
May 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
Open Questions:
8,255 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
