Question about Mercedes Benz Travel Alarm Clock
97 s500 had for 6 mths- just a few days ago the automatic locks for trunk or doors will not work- with key or console button. Thanks
    Problem Solver:
  • 7 Answers
Since its a 97 Im pretty sure not the only owner. Some one possibly had an alarm uninstalled and didnt properly connect wires back, and now they came loose. Just check all connections on door panel to see if theres any signs of tampering
Posted on May 14, 2010
SOURCE:
Remote won't work, can't start car (alarm system goes off) Also, key won't turn manually in door. FYI` car battery replaced a few months ago. Also tried replacing batteries in remote. When I parked the...
Open the trunk with the key, it will disable the alarm. You probably need a new door lock cylinder, which you should look into. They're easy to replace, but take a while to get, as they have to be coded for your key. You can also remove the door lock cylinder by loosening the t20 torx screw near the door handle until the lock cylinder slides out(DO NOT LOOSEN MORE THAN NECESSARY TO GET THE LOCK CYLINDER OUT), then use a flathead screwdriver through the hole to activate the lock.
Feb 06, 2011 | 1998 Volkswagen Beetle
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
I HAVE A BMW 735i I WANT TO KNOW WERE IS THE TRUNK OPENER?? I COULD NEVER FING IT.
Go to the trunk and put your key in and turn it all the way to the left and remove the key. This way by pushing the button at the trunk it will open, the trunk will lock when your doors are locked and the trunk will unlock when the doors are unlocked allowing the button at the trunk to work at that time. I'm not quite sure if your system works that way, or Try pushing the button that opens the trunk down by the hood release latch, or, you should have a remote key with the trunk open button on it, it should have 3 buttons, one is lock, one is open the car and one is open the trunk, if you have the automatic opening trunk, this should be the same, and to close it, just press the lock button and it should automatically go down again, as you did not specify what year yours is, one of them should do the trick...hope this helps
Oct 21, 2010 | BMW 7 Series Cars & Trucks
The cable for the remote in the trunk came loose, now the trunk won't open with either the key or the button on the door. what to do?
You should be able to go in through the back seat. It will be a chore to remove the seat, but will probably be the only way to get in there. There is a safety release cable in the trunk that will opne it the lid for you once you get inside
Sep 05, 2010 | 2000 Buick LeSabre
Cant get my 99 xj8 out of valet mode, and my trunk will not open.
There are Valet keys (often with a green knob) that will
only unlock the front doors and the ignition but not the
glove box nor boot/trunk.
When either the front door locks or the console button is
pressed, all the doors should lock. Likewise, when either
front door is unlocked, all the doors fuel filler lid and if
selected, the boot will also unlock.
Boot lock has three positions. Unlocked to the left,
automatic with the doors in the center, always locked to the
right. Simply remove the key in what ever position you desire.
The locks can get confused and not work correctly. Simply
sit in the car and manually lock all the doors. That will
usually get the locking module sane again.
Feb 28, 2010 | 1999 Jaguar XJ
My gas cap and trunk wont open. I need gas. Te button on the console won't release the gas cap to open or the trunk. Audi TT 2002.
Take your key and go to the drivers door, make sure the door is unlocked by pulling on the handle, open and close the door. Insert the key and "lock" the door, double check that it is locked by pulling on the handle. Insert the key and "un-lock" the door, use the handle to open the door and now press the fuel door key and it should open, same for trunk release button.
Audi's are a strange breed, sometimes you just need to "re-set" some stuff. But in the future if you lock the car with the key, the fob will unlock the car but the three buttons in the console will not work, the fob will function correctly.
I hope this helps.
Feb 27, 2010 | 2002 Audi TT
Remote trunk release stopped working.
see if there is power at the solenoid with the button pushed inside the car. if so change the lock solenoid. best of luck
Aug 07, 2009 | Saturn SL1 Cars & Trucks
Crazy Electrical Problem in 2005 PT Cruiser
Either wire harness problems or you got a so called lemon
One of the first books of Ralph Nader about auto industry.
Had a Hyundai like that 27 years ago. Until I took it totally apart and re-assembled it myself. 2 years ago bought a Piaggio 45 cc motorbike, same story. Took that apart one night and put it together as should be.
Apr 15, 2009 | 2003 Chrysler PT Cruiser
Door and trunk locks wo'nt work/turn with key
sounds like you may have the wrong key
Jan 28, 2009 | 1996 Ford Taurus
Mercedes Benz Travel Alarm Clock Logo
173 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
