Sharp AR-5316 Advanced Digital Imager Copier Logo
Posted on May 12, 2010
System error 4-00 - Sharp AR-5316 Advanced Digital Imager Copier
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
952
Points
8
Your problem is displaing 4-00 error code but it is not clear code befor 4-00 any alphabatic latter is displaing so, please tell full error code
like H-4-00
if H-4-00 code then go to dignostic code and press 14 and then press start button then wait it will rest your error code
it will restart it self after 1 second
now can strart your work machine is working ok,
130 HP 2 stroke Yamaha over temperature alarm. I have replaced the water pump and thermostats. i get high temp at high RPM (3,500-4,00) but not at low speed (1,500 - 2,500)
Try disconnecting the alarm sensor wire going to the top of the head. I think it is a pink wire. Clean it and try it again. If that does not fix it, you most likely need a new alarm sensor.
No electricity spark plugs 4,00 liter
check all fuses first, every time, something fails EFI.
the scan tool will tell you why 90 % of time.
connect scan tool
key on
crank for 5 seconds, see scan tool show 300 RPM? about.
good, no RPM is bad sensor (Cmp or ckp)
release key , do not turn off yet
see DTCs stored, now, bingo, its telling you what is bad. OMG.
p0340/ 355? and the like? are bad CMP, bad CKP, or others get em
post em or look them up in the FSM. or at alldata.com
Theory:
the ECU creates spark
there are the 2 sensors that tell the ECU when to spark (inputs)
and the ECU DRIVER the ignition IGNOTOR, that runs the ignition coil.
1 coil or 6 coils. depends on year.
4.0L I6 Jeep engines.
did you check for spark directly at the 1 coil car or at all 6 coils for 6 cop coil cars?
cops are coil over park plug, i think your car is 1 coil, had a 99 jeep.
and this old six still had one, coil, so does this one coil make spark
to a test spark plug, Y/N
if yes, the dizzy cap is bad or wired wrong. to plugs.
I no spark here, do the DTC scans above.!!!!!
post back results.
My HP 12c is showing 0,00 on the display...if I add 2 plus 2 it shows 4,00. Not sure how to reset? It also has a blinking * which I understand is a low battery indicator...are these two things relat
No, they're not related.
To switch the radix mark, turn the calculator off, press and hold the decimal point key, press the ON key, then release both keys.
3helpful
2answers
AOD270-1824 can i put a 4gb ram in it
You can add 1GB of ram but that's it. Definately not a 2GB Stick or 4GB stick.
We have a Sunjoy table top patio heater without the propane tank that fits inside. The heater number is L-PH007PSS-B. Where can we order a replacement tank from? Thank you. Pat
Pat, the model you have uses a 1 Lb tank, that can purchased at any hardware store or home center. It's the same size tank that Coleman stoves use. They run anywhere for $4,00 -$6.00.Unfortunately, you can't order full tanks, because of Hazmat issues in shipping to you.
Hope this helped you. Please let me know.
When i try to upload pictures from the camera it causes my computer to restart everytime. Windows EP
Sometimes some operating system is not compatible with such cameras.
therefore,the best way to unload the pictures please try to obtain / buy a USB multi memory card reader (it is about 4,00-6,00 USD ) and take your memory card out of camera ,plug into card reader,USB to computer ,here it is ,your pictures there ( to be seen as external Hard disc )
Regards.
Mar 02, 2010 • Photography
2helpful
Looking for manual for a west bend bread maker model #41065
Here is a site.Check the first "Get This Manual"
and you can buy it for $4,00. Check the second "get this manual and you can download for free
Hope this helps
Pls rate the answer
Kurt
http://kitchen.manualsonline.com/manuals/mfg/west_bend/41065.html?s=fpw
2answers
6helpful
2answers
My 2000 ford explorer turns over but wont start
yes the fuel pump is running, you know because when you put the key up and ready to start you can hear it. I know just what you are talking about I have had that same problem. It is about a $4,00 part should not be more then $10.00. So open the hood and then go to the fuse box you will want to change the fuel pump relay that is in the middle of power point and pcm power relay. Also there is another that has to do with the fuel and that is called fuel system this part is located on the right side of the fuse box and the other is on the left.
I hope that you have every thing work out for you please let me know what happens I hope it works out well.
Nikki2913
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
