Adjust the valves when the lifter is on the base circle of a camshaft lobe:
You will have to take the valve cover off, ten to one you will need to replace the gasket.
This can be done two ways:
when you have the cover off and the one you want to adjust,rotate the engine until that valve is fully closed, turn the push rod by hand while thightening the nut, when the rod gets snug, but not tight, that should do it. Repeat if necessary.
Now the messy way,
with the engine running, tighten each one down till the clicking noise stops, but turn the nuts slowly, It's messy, cause oil spatters all over.
