Behringer Pmp3000 16 Channel Audio Mixer Logo
Posted on May 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get the effects to work on the mixer
Im pretty new at this...Just got a new Xenyx behringer 16 input mixer and got everything to work...Just trying to figure out how to add a little reverb to the voice and cant seem to figure it out...Says it has effects included in the mixer. Not to sure how fx works and manual doesnt go into any kind of detail I find...Thanks for anyone that can help..!!!
steve Riley
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Dec 22, 2014
steve Riley
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
1134
Points
The efx master and channel efx send are the same usually the sane color. Whatever channel the mic is in turn the efx knob on the channel up and make sure the efx master is up
Fred Yearian
Level 3:
  • Behringer Master 5,603 Answers
  • Posted on May 12, 2010
Fred Yearian
Behringer Master
Level 3:
Answers
5603
Questions
Helped
2247565
Points
16162
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
1helpful
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
Behringer Xenyx 502 Mic buzzing...PLEASE HELP
Get yourself anti-static spray and spray over the connector before inserting into the jack, most times its dust or static buildup which causes that buzzing sound and in other times replace your mic
I have a Behringer eurorack ub1002 mixer. how can i open it up to fit a new socket on the face of the desk. I seem to have unscrews all the screws
One has to remove all the knobs, including the faders. There are MANY screws through the panel AND all the 1/4 inch jack hardware has to be removed. Remove EVERYTHING else BEFORE removing the small screws... It is a LOT of work, although this mixer is small compared to some! Be careful to NOT scratch the circuit board as Behringer uses very small/narrow circut traces that are easily damaged. Make sure you have the EXACT same socket so it not only lines up with the holes but is the right height from the circuit board, Temporarily mount the socket along with the mating ones before soldering the pins so it is in perfect alignment to fit the hole in the panel.
I cant get any output in sonar 6 ahd yes the rack is active im new to sonar just the mixer xenyx xl 1832 usb
Make sure Sonar is set to use the Xenyx for the clock in the audio options pull down menu. It often defaults to your PC soundboard.
2answers
Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
Im try'n to hook a ''Duel fex pro'' multiband sound enhancement processor model ex 220, to my berhinger xenyx 1222fx mixer?
Use four (4) TRS cables. Connect from the
AUX "send" (left and right) to the input of the effects unit with two of the cables. Use the other two cables to connect from teh effects out jacks to the AUX "returns" left and right.
1helpful
3answers
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
1helpful
3answers
How do i hook 1202fx to computer?
just connect a baby plug to rca from the pc to the mixer respectively
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
