Could not install the full features for the hp 6310 all in one printer for windows 7 64 bit. However windows 7 found all drivers needed and it does print and usb card read. What does not work is the scanner function. I have tried to uninstall / reinstall the drivers and still fails. The only thing that works is having it off. Removing it from devices and when it boots up into windows again, turning it on and reinstalling. Scanner still does not work.
When trying the scanner diagnostics from hp it cannot find device.
SOURCE: HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
SOURCE: scanner and coiper won't work printer does work
Hi Bbear,
The problem here is with the scanner bulb, the scanner bulb is bad.
I mean to say that your scanner bulb lit for a while and goes off.
This confirms that the scanner bulb is currupted.
I have a web link, which is given below with some of the troubleshooting steps to perform.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu01105&cc=us&lc=en&dlc=en&product=390315
Click on the web link given above and perform the steps.
If this fixes the issue, that would be great else you need to replace or get a new or refurbished printer.
SOURCE: HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,
raj_p5983
SOURCE: chronic message "No Hp Devices Detected"
Here are HP's solutions for this problem in Vista and XP:
Are you running Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01474870&cc=us&lc=en&dlc=en&product=1153481
IN XP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01577383&cc=us&lc=en&dlc=en&product=1153481
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
