Apparantly the default ip address is wrong to the one my provider give me...
how can i change it back to the right one?
thx!!!
none as I dont know how
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
How to change the IP address that is assigned to a network adapter
loadTOCNode(2, 'summary');
1.
Log on to the computer by using the Administrator account.
2.
Click Start, click Settings, and then click Control Panel.
3.
In Control Panel, double-click Network and Dial-up Connections. The Network and Dial-up Connections dialog box opens.
4.
Right-click the local area connection that you want, and then click Properties. The Local Area Network Connection Properties dialog box opens.
5.
In the Components checked are used by this connection box, click Internet Protocol (TCP/IP), and then click Properties. The Internet Protocol (TCP/IP) Properties dialog box appears.
6.
Continue with the steps in one of the following two sections.
How to automatically obtain an IP address
loadTOCNode(3, 'summary');
Use these steps to configure the computer to obtain an IP address from a DHCP server. Note that you must have a DHCP server.
1.
Click Obtain an IP address automatically.
2.
Click Obtain DNS server address automatically if you do not want to specify the IP address of the Domain Name System (DNS) server.
3.
Click OK. In the Local Area Connection Properties dialog box, click OK.
4.
Click Start, and then click Run.
5.
In the Open box, type cmd, and then click OK.
6.
At the command prompt, type ipconfig /release, and then press ENTER.
7.
Type ipconfig /renew, and then press ENTER. The network adapter is assigned an IP address by the DHCP server, and a message similar to the following message appears:
Windows 2000 IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :dns.microsoft.com
IP Address. . . . . . . . . . . . :192.168.0.201
Subnet Mask . . . . . . . . . . . :255.255.255.0
Default Gateway . . . . . . . . . :192.168.0.1
8.
Type exit and then press ENTER to quit the command prompt.
How to specify an IP address
Follow these steps to assign an IP address to the network adapter.
1.
Click Use the following IP address if you want to specify the IP address for the network adapter.
2.
In the IP address box, type the IP address that you want to be assigned to this network adapter. This IP address must be a unique address in the range of addresses that are available for your network. Contact the network administrator to obtain a list of valid IP addresses for your network.
3.
In the Subnet mask box, type the subnet mask for your network.
4.
In the Default gateway box, type the IP address of the computer or device on your network that connects your network to another network, or to the Internet.
5.
In the Preferred DNS server box, type the IP address of the computer that resolves host names to IP addresses.
6.
In the Alternate DNS server box, type the IP address of the DNS computer that you want to use if the preferred DNS server becomes unavailable.
7.
8.
Close the Network and Dial-up Connections window.
Back to the top
Troubleshooting
There is an IP address conflict: If you attempt to assign an IP address that is already in use, you receive the following error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address. In this case, assign an unused IP address to the network adapter.
Your computer cannot connect to other computers on the network: If you assign an incorrect subnet mask address to the network adapter, the computer is effectively located on a different network. You cannot connect to other computers on the network.
Your computer cannot connect to other computers by using host names: If you assign an incorrect DNS server IP address, or if you do not use a DNS server, you cannot connect to computers by using their host names. This prevents you from browsing the Internet. You can connect to other computers by using their IP addresses.
You can work around this issue in a local network by adding host-name-to-IP-address mappings in a Hosts file.
Kindly give a feed back to Improve my statistics by Rating My advice and to see If it was helpful for you...
Thanks and Regards
Pleas advise me how fix the problem for two of my computers havinf IP ADDRESS. The problem started when I purchased a new PC and removed the old one from the wireless Router and connect the new pc. I get error messages indicating two pc with the same IP Address. Can you help?
ip address for what?
want to change IP address
