we have a beko wm5121w 5kg washing machine keeps cutting all the electics off (only 2year old)you can open the door with washing inwe have a beko wm5121w 5kg washing machine keeps cutting all the electics off (only 2year old)you can open the door with washing in
AnonymousMar 12, 2014
hi my washing machine wont finish its cycle it keeps stopping and beebing eight time in a row and does it whilehi my washing machine wont finish its cycle it keeps stopping and beebing eight time in a row and does it while
AnonymousMar 23, 2014
model number WMC6100Smodel number WMC6100S
AnonymousMar 27, 2014
What does -C.L- mean?What does -C.L- mean?
You can't post conmments that contain an email address.
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer
This video will show you how to keep your soap draw clear
and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
see the next steps and use the common sense: God bless you When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer. It
may be a cold-water supply problem, if the washing machine fills with
water, agitates, drains, and spins, but then doesn't fill with rinse
water. See There's no cold water.
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
