No booting up
Hello
For your problem i think it might by the 2 reasons
1. The HDD Cable and Power Cable is having loose contacts or
2. May be the OS Problem
Step 1:
Remove the cover of the cpu
check the HDD cable and the power cable is fixed correctly
and restart the system
Step 2:
Re-Install the OS with a well known expert
Let me know if your problem is solved and rate me as FIXYA!
Things to Check When No boot...
1. Have you connected all the power cable?
2. Do you see any display?(including the power lights glowing)
3. Does the screen show you any blue screen error message?
4. Do you hear any beep noises?
5. Have you tried to install any third party hardware or software?
6. What do you think could have caused the issue?
It can be a number of things
1: Check in BIOS and make sure the HDD IS detected
2: Make sure the boot order seems OK; make sure the HDD is set to first boot device as a simple check.
3: Make sure no peripherals are plugged in, i.e. printer (to rule out any 3rd booting options)
If everything seems OK, then that's when we'd try a system recovery, stick in the recovery CD / XP CD.
If it boots into the recovery Console then we can do chkdsk /r - If that comes back OK, try and run the complete restore.
If it goes through OK and in to Windows then problem sorted just a software issue.
If it goes through OK but then comes up with the same issue, could be a fault with the HDD.
