The door is locked firmly and won't open, even when the machine is turned off. When I turn it back on and try to start a wash cycle of any kind it clicks several times (as if trying to lock or unlock the door) and then freezes with the code "F22" flashing.
You can't post conmments that contain an email address.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
Translate this page
Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
Translate this page
Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Hi, "F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed. In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug. Thank you !!
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway. If you're getting an F22 error, you will want to check anything to do with the door latch switch.
After six failed attempts by your machine to lock the door F22 flashes. Causes & Procedure: Door lock mechanism is broken or removed from door. Door switch or door unit failure.
1 Unplug / disconnect washer. 2 Check door switch lock unit. 3 Check wire harness connections to door switch/lock unit & the Central Control Unit (CCU)
Fault 22 Push the door to make sure it is locked firmly (try some WD40 on the door mechanism on machine, not on door, to ease out any lock jam & try the door open/close with the power off the wall) I'm giving you tips to avoid the so-called techs zooming for your wallet.
Fault 28 The communication between the CCU & the MCU (motor control unit cannot be sent correctly.
1 Unplug washer / Disconnect power 2 Check wire harness connection to the MCU, the motor & CCU Check communication of the CCU board within the housing. Make sure all grounding switches are engaged. 3 Check the drive system for any worn or failed components 4 Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors. 5 Verify CCU operation by running the Diagnostic Test or any cycle after plugging in.
Will try getting back re the door lock. Desperate i know, so am i.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.======= It's noisy
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
unplugging washer did not help. Door is still locked
