Apple PowerBook G4 Mac Notebook Logo
Posted on May 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant find the disc on my powerbook g4
Cant find the disk on my powerbook g4, want to save my pictures tried mac migration, nothing, network nothing, when tried to install leopard again, no destination disk appears, firewire does not help, what can i do? thank you
Anonymous
Level 3:
  • Master 1,305 Answers
  • Posted on May 11, 2010
Anonymous
Master
Level 3:
Answers
1305
Questions
0
Helped
595944
Points
4327
STart up your G4 using the OS disc for leopard, but instead of reinstalling the system, go to the menu at the top of the screen and Launch Disk Utility.
You may need to remount your hard drive. The disk utitliy can do this for you. Then it should appear in the disk utillity window. Then you should be able to install the OS and away you go!
Powerbook g4
If you have the operating systems disk, you can boot from the disc, and once the setup come dump, choose password reset from the "utilities" drop down menu. Change your password, shutdown, and reboot.
HOW TO REFORMAT THE POWERBOOK G4 LAPTOP
Boot from the 10.3 disc by holding the C key down. When
you see the Installer window, go up to the Installer Menu to
Disk Utility and use that to reformat the drive.
thank you for using fixya,
your's caringly,
shoeb
DONT FORGET TO RATE OR VOTE ME
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
Cant install so 10.2 onto powerbook g4.
Remove both RAM chips and re-insert, because sometimes they come loose. Now give it a shot old chap. Also, your RAM chips may have died, so insert new ones and give it a shot.
Don't install Panther 10.2, because that operating system (OS) is too old. The PowerBook runs best with the Tiger 10.4 OS. You need to install a retail version disc with black label instead of a gray label disc, because those discs are computer specific to certain models only.
Cheers
1helpful
2answers
I picked up a Powerbook G4 12' Aluminum guesing 1.5 from a local college that was going to trash it, and when I press the power button the start up chime rings and turns straight to a blinking ?/Mac OS...
Get the gray OS discs specific for the PowerBook. Your iBook gray discs won't work. You can also install the OS by getting a black label retail version disc of whatever cat you like- Panther or Tiger. If the software installs, but you hear noises or get the spinning beach ball of death, then the hard drive is fu.k.d up. You then have to open up the computer and install a new hard drive and re-install the OS. Good luck old chap. Cheers.
2answers
How to save data from hard drive off my apple power book g4
You can drag and drop your files on to an external hard drive or USB flash drive, burn the files to CD/DVD using an application called toast - you will need a CD/DVD writer to do that. If you can find one, you can save your files to a zip disk.
1helpful
How to reset the master password for g4 mac powerbook ?
1. Obtain a Mac OSX install disc (buy one from apple or try Ebay) 2. Insert the disc then click on the "Install Mac OS" icon. Then click the restart button. 3. DONT INSTALL! Just click through enough of the windows to get to the regular set of choices on the menu bar. One of those choices is UTILITIES and one of the choices there is RESET PASSWORD.
Simple, but you should know that anyone with a Mac OSX install disc can gain access to your computer.
1helpful
Restore CD
You don't need a "restore" cd.
You can just use any copy of Tiger.
Borrow one!
DVD player skips audio and/or frames
PowerBook G4 is at least a five-year-old machine at this point. A DVD drive can **** in lots of dust in five years. Try hooking up to an external DVD drive. If it plays the same discs with no problem, you need a cleaning or replacement. Frankly, an external DVD drive is cheaper than replacing your internal drive.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
