For most front-loaders:
Open the top of washer, screws behind, slide away from front couple of inches & lift up. Lubricate the slot which fits over the tub with washing-up fluid, if there is resistance to insert.
Starting at the top, press the seal so the flange of the tub enters the
slot on the seal. Work your way round the using thumbs to force the slot
on the tub flange. When slot is on the flange all way round, fit the
spring which holds it on. The spring goes into a slot on the outside of
the seal. This is quite difficult and you may need another pair of
hands. Fit the outside of the seal to the cabinet - this
is easy and fit the plastic clamping ring.
Test for leaks before
using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Pl rate me ‘very helpful’ for the free help!
