3Com NBX 3102 IP Phone Logo
Posted on May 10, 2010
The sytem says its waiting for NCP and has the NCP light light. How can I reboot or fix the problem
  • Anonymous Sep 06, 2012
    What if I can't reset the router, because my Ethernet is connected to a pretty large network, and I don't want an internet outage, even for a short time? What should I do then?
NBX_Tech
Level 1:
New Friend:
  • Contributor 58 Answers
  • Posted on Dec 04, 2014
NBX_Tech
Contributor
Level 1:
New Friend:
Answers
58
Questions
0
Helped
23442
Points
63
This means that the phone and the NCP (Network Call Processor) in the phone system aren't communicating with each other. Multiple problems can cause this. Things to check:
1. Network cable - Is it plugged in, and to the right port?
2. Phone died
3. Is there an available license? (3100 series phones)
4. Is there a network switch problem causing a loss of communication through whatever switch that the phone is plugged into.
1 Related Answer
Anonymous
  • 3278 Answers
  • Posted on Aug 29, 2011
SOURCE: I get the message: 3Com Model
Hello.
NCP stands for Network Call Processor. There is a problem with communication. Since your server is running, reset your router (disconnect power, wait a few minutes, then reconnect) that supports your IP phone.
Hope this helps.
Receiving a mesage:Boot from ATAPI CD-ROM NO EMULATION
Set the computer BIOS to boot from CD first, remove all the flopies, put in the CD, and reboot the system, and wait for the prompt "press any key to boot from CD ..." -- immediately press some key, and run install from the CD.
You have to boot from the CD, you can't 'run' it from inside the sytem.
3com 3102 not working
try 192.168.2.1 / 192.168.2.0 / 192.168.0.1
hope it works.
enjoy
When turned on it it loads operating sytem and then blacksout
Turn on your computer then Press F8 rapidly until a troubleshooting choices appear, choose SAFE MODE and wait for it to load. After booting to windows safe mode go to start>run>cmd and type chkdsk /r then reboot.
I get the message: 3Com Model 3102- Wait for NCP M We have never seen this before and it is after a power outage. Our server is running. What is NCP?
Hello.
Hope this helps.
Panasonic kx-nt265 npn tunnel, can ping ip
Is the 265 connected via a TDA on the old IP ext card or the newer NCP or TDE if its on the TDE or NCP check the phones software may need to be upgraded, thats the only problem I have ever had with the KX-NT265 I now only use the newer KX-NT321 or NT343,346 etc
2answers
System inactivated inadvertently
Reboot voice mail system hopefully it will come back wait a good five minutes before trying
1helpful
Reset photoconductor unit gestetner dsm415
Zeroizing the counter Fotocondactor. The Sign - twinkle all lamps, in readiness not vyhodit.
1 To Press "copy" and include feeding with pressed кнопой. All indicators, except "Ready", light.
2 Release "Copy", press her(it) once again and keep until it is ed indicators "Toner" and "Paper" 10 sec
3 Release button. Switch off feeding, wait 15-20 sec, include once again
3answers
Playstation has a yellow light blinking and have a game inside won't come off
yellow usually means a sytem error. Try to power the system of, wait a couple of minutes and turn it back on and try to eject the game as soon as you turn it on. then when the yellow light is gone try to play your game again. good luck!
Ubuntu fixing ntfs filesystem
If u have problem with fixing NTFS so please visit this website
http://www.ubuntu.com/ so that this a new operating system
even i am waiting for the CD's to check this operating sytem
If u have more clarifications u can go through this website
Laptop startup problem
hello.
You have a system error on the operating sytem. try reinstall the windows operating sytem this will resolve the problem. if not then maybe you should refpormat and reinstall the system. melnavz
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
