A
Anonymous Posted on May 10, 2010
Hello,after refilling ink cartridges HP21 and
Helloafter refilling ink cartridges HP21 and HP22I instaled them to my hp Deskjet F4180 printer.when there is only HP22-color cartridge in printereverything works.but after installing hp 21-black cartridgeprinter shows an error( and it doesn't want to print).i did reset both cartridgesbut black one still seems to be the problem. If u can help methat would be great. Thank you Martin
Dr Tony
Level 2:
Novelist:
  • Expert 142 Answers
  • Posted on May 10, 2010
Dr Tony
Expert
Level 2:
Novelist:
Answers
142
Questions
0
Helped
38893
Points
295
Since HP’s ink technology is different from other manufacturers, they do not recommend to use refilled or remanufactured ink cartridges. Though the cost of genuine HP cartridges are bit expensive than the other cartridges, HP cartridges are manufactured in keeping mind the important factors print quality and customer satisfaction. Using the refilled cartridges may degrade the print quality and may damage the printer’s internal hardware.
I request you to use genuine HP Inkjet cartridges and verify the result.
:) Dr Tony
1helpful
I just installed new ink cartridge and light blinking cant print p0ls help F4185 printer
Maybe u used refilled cartridge?
You must be using HP21.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP f4180 is not a new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
1helpful
Printer (HP deskjet F4180) showing E and color
This means that there is issue with the Ink Cartridges.
Please remove and re-insert the cartridges.
Check the expiration date on them. Also make sure that you are using genuine HP Cartridges, not refilled or Remanufactured.
If the issue still persists, please replace the ink cartridges.
Installing ink cartridges
don't know how to install ink in my f4180 printer. Have new cartridges 21 and 22
1helpful
Hello,after refilling ink cartridges HP21 and HP22,I instaled them to my HP Deskjet F4180 printer.When there is only HP22-color cartridge in printer,everything works.But after installing HP 21-black...
Most times during a refill if you leave the cartridge out for any length of time the ink dries on the printhead or nozzels and wont allow the cartridge to print.
You can clean it manually with rubbing alcohol or try to use the printhead/cleaning feature built into the maintenance software installed on your computer.
Most times you will have to replace the ink cartridge.
Regards
1helpful
2answers
Printing problems
If you don't use the printer often it is possible that the ink gets dried inside the cartridge, hence you get the print out with low quality or blurred. We suggest you to use original HP cartridges and keep using the cartridges frequently.
Thank you for using Fixya.
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
I have a HP Deskjet F4180 AIO. It is printing
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
Refill ink is giving me a error on my printer
Try another ink cartridge. Thats what I did. I found out that one of the ink cartridges I used was defective and actually had no ink so the unit was reading an error.
Hp Deskjet F4180 and incompatble ink #27
This cartridge is no compatible with your printer. You could use refill kits for your original cartridge so you always have ink arround.
Try here for more options
2answers
Ink cartridges
i advice you to use the compatible cartridges, else maybe can outhers cartridges make a damage to your printer.
if you want more copies find anouther printer
k24674
ADMIN Andrew
ADMIN Andrew
