Give it a thorough cleaning.. if it still does not fire you might have to replace the spark plug.
Little Suggestion Internal there can be a problem in the upperpart circuit thats been mechanically actuated by the safety bracket that is pushing on a microswitch that bracket on the nailers front can be a little bent.
Check to make sure the driver is returning to the start position. If it isn't then remove the battery and push it back with a small flat ***** driver until it stops. Fire it again and check to see if the driver is in or out. If it is out, then the exhaust and piston ring needs to be replaced.
Check gas expiration date or could be bad gas
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
fuel can may be too old, don't trust date on can....
