Unscrew the top head of the flashlight and check the contact points next to the bulb. if all else fails buy another one and take that one back and tell them it's defective.
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
SOUNDS LIKE IT IS CORRODED. PUT A FEW DROPS OF RAPID TAP TAPPING FLUID OR A FEW DROPS OF THIN MACHINE OIL AROUND THE CAP. LET IT SIT FOR A FEW DAYS AND TRY IT AGAIN.
take the bottom piece off, remove the last battery and put a coating of petroleum jelly on the threads of the tube. Then take the bottom piece and run it all the way in and back off and back in 2 or 3 times. Then put a little more petroleum jelly on the threads and put the battery back in and the bottom piece. This should do it.
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out. (My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Ok, problem is the acid has corroded and caused a white powder residue to form, you will have to spray a solvent into the torch to free the batteries... bad news? the corrosion cannot be fully cleared and the maglite will always be on the blink... sorry but i have tried several times for people and just cannot clear it out fiully
Unfortunately not, I've seen more and more of these coming back to the shop here with faults. Mostly they seem to be connection problems like yours. Pity, MAG are excellent and have really tarnished their reputation with this LED gimmick. A lot of the customers who return their LED's to us take a traditional MAG as a replacement..
