Golden Technologies Companion II travel scooter won't move. light flashes seven times indicating potentiometer problem. I replaced thumb controller and control panel (with old items from previous same-model scooter). Same problem. Any other suggested immediate fixes? Disabled rider - scooter vital in all respects.
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
According to the owner's manual, you have a motor problem. To further diagnose and verify the problem you would need a digital voltmeter to check the motor. An experienced technician can do the necessary checks and order/replace the motor if necessary.
8 Flashes
• Indicates a motor voltage problem.
• Your scooter will not operate until the problem is corrected.
Remedy: Contact your authorized Golden Technologies, Inc. dealer.
Hope this helps.
i have a question if i hit my shop rider on a angle coming in my door way would it bend the under part of the front of my gopher i done it 3 times at very low speed
