Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Ovens dont work properly
My left oven will only stay on low and go no higher and my right oven stays on high and can't be turnt down resulting in everything being burnt plz advise i purchased this of someone else, was told in good working order it looks brand new, rest of the cooker works great. the right oven get's that hot the handle and the knobs above it, get roasting hot
SOURCE:
SOURCE: Left hand oven not getting hot!!
If there is a low flame then the chances are the mercury flame protection device is broken. This is a safety device that protects the cooker from allowing full gas flow if the flame fails. However if the switch is broken then it won't allow full gas on to the burner. Hence a low level of burner which does not get very hot.
Posted on Dec 17, 2007
SOURCE: Fan oven door, cooker surround and hob become burining hot when using fan oven
I have the same, but my fan is running slow too, and the oven completely turns itself off and then on in around 10 mins ?
Someone told me it was the Oven Fan Control PCB, but I have not replaced this yet. We will see soon. Good luck
Posted on Sep 09, 2008
grandadfixer
  • 99 Answers
SOURCE: Both electric ovens do not work.
Have you set clock time?
Posted on Oct 11, 2008
SOURCE: Rangemaster 110
i have had the same problem with rangemaster 110, r/h solinoid,i purchased a replacement from an authorized dealer, same fault within 6 months, i had to purchase a replacement so they could check the first replacement was faulty before they refund my money. now the second one has failed. so we have decided to use it until the l/h oven gives up (hopefully sooner than later) then we will be buying another double oven, but it will not be rangemaster.
delboyp
Posted on Oct 28, 2008
  • 160 Answers
SOURCE: Gas oven
Its the flame failure device faulty (FFD)
Posted on Feb 22, 2009
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 | Ovens
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Burner heats to high even when set on low
Are you talking about the cook-top part of this unit or the interior of the oven? If it's the top part, your infinite switch is out. If it's the interior, it's one of the elememts. If you will give us a call as soon as you get a chance, we'll make sure and get the correct part out to you right away to get this repaired. We look forward to working with you and getting your oven fixed BEFORE Thanksgiving. 972-859-0929
Oct 04, 2009 | Ovens
I have a Magic Chef Chateau Gas range. The upper oven does not heat properly. It comes on, but never gets up to operating temps.
you could have a bad ignitor check that it is actually igniting the gas and you can see flame, also check the cavity sensor a probe that sticks into the oven at the top usually on the left top corner but if the bake cycle works with good results them it is ok
check for flame when it starts give it a mibute to ignite, if it does not then you need to replace the broil ignitor.
Sep 19, 2009 | Ovens
Beumatic oven
my emilia gas oven wont stay on
Apr 26, 2008 | Baumatic B187 Electric Single Oven
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
