Whirlpool 7 cu. ft. Chest Freezer EH070FXM Logo
Posted on May 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red light on
Hi the red light came on on my freezer, someone plugged it out by mistake and this light came on when it was plugged in again. I dont know what its about
Anonymous
Level 3:
President:
  • Master 2,468 Answers
  • Posted on May 09, 2010
Anonymous
Master
Level 3:
President:
Answers
2468
Questions
0
Helped
707042
Points
7484
You should have have let it sit till the compressor equalize if it was running,you may have ruined the ptc overload relay that protects the compressor,try unplugging it and leave it off for an hour,then retry it,if this doesn't help then replace the ptc overload on the compressor body,they just unplug off the compressor
Why is the red light staying on on my freezer
Maybe if you should specify what that red light is supposed to mean, indicating by the way make and model of your freezer, someone might help you about issue.
Aug 31, 2015 • Freezers
Proline freezer helpline
The red light is usually just a power on indicator and should always be on as long as the is voltage is being supplied to the unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 27, 2017 • Freezers
1helpful
My freezer hi temp alarm was going off now it intermittently works 16.7 cu. ft and alarm goes off again
Hi Joseph, I am happy to assist you. If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
1helpful
2answers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 • Freezers
1helpful
Lec freezer if i turn thr temperature up the red light starts to flash
that is because when you want a colder unit the sensor is detecting a warmer interior hence red warning light comes on.leave it at the setting you want and within 24 hours the red light will go off.
strongly recc you use a freezer temp gauge so you dont get rock hard ice cream(-18C is best)
Mar 23, 2010 • Freezers
Red light on not green ...has to be green to freeze up again
Try to unplug it for about 5 minutes, and then plug it back in
Apr 17, 2009 • Freezers
Red light on
Glad to hear it went well. Please give appropriate feedback for me, thanks again.
Nov 13, 2008 • Freezers
2answers
FRIDGE FREEZER
What freezer not above.
Thanks J
Jan 03, 2008 • Freezers
Light on freezer
This just means that you have power to the freezer.  It's letting you know it is plugged in.
Oct 11, 2007 • Freezers
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
