4 Solution that fixes Error Code 5011 in Canon Printer:-
Solution 1
Remove all the power cables from your printer.
Wait for 5-10 minutes.
Now, plug all the power cords back into your canon printer.
OR
Once you close the printer you should open the printer cover that you need to open when replacing the ink cartridge.
Turn on the printer and close the printer cover when turning on the printer.
OR
Turn off your printer.
Press and hold the power button + cancel at the same time.
Release the Cancel button by pressing the power button.
Now, click the power button 4times and then you can release both the cancel and the power button.
Solution 2
Sometimes,
Canon Printer Error Code 5011 can also take place due to missing paper inside the Canon printer. It is suggested that you check the inside of the printer and check for the bits and chunks of paper stuck inside. If you found any, you have to remove them carefully without leaving anything behind.
Solution 3
The encoder strip of your Canon printer is present on the back of the carriage that runs from right to left. You have to clean the encoder strip using a dry, clean paper towel.
Solution 4
If the error persists then you can also change the scanner's unit of your printer and also concern it with us by calling on our toll-free number.
The Toll-Free Number is in mentioned Blog that is above.
