Question about NorStar Meridian M7310 Phone
Norstar M7310 auto attendant problem
Our auto attendant gives 4 options. Each option directs caller to a specific extension. I know how to change the recording but how do I change the extension the caller is directed to.
  • Anonymous Mar 12, 2009
    We have a norstar M7310 phone system with an auto attendent I need to change the number of rings before the AA picks up.
As far as changing the # of rings, that may be your phone company. Feature 983 will get you in to change to number of rings. It goes as follows:
Feature 983
System coordinator mailbox # and password
OK
AA
Lines
Enter Line Number
OK
Table
Rings
CHNG
Enter the desired number of rings
If after changing the number of rings the Auto atendant does not pick up at all, You have to call your phone company and set up the second delay through them. We had the same problem here.
Posted on Mar 16, 2009
SOURCE:
How do I turn off the auto attendant on my Norstar M7310?
It depends. Go into feature 983, default pwd of 1020000 for 3-digit extensions. Go into AA, Table, Table 1, and change the option for the AA to N. If you're using a CCR tree, you'll have to go into Table 1 and disable the tree under Morn CCR and all the CCRs that follow.
Mar 03, 2015 | NorStar M7310 Corded Phone
After I change the greeting on the auto attendant on a Norstar M7310 I don't get an option to save, how do I save it
You cannot change the active message. Make it inactive, change it, then make it the active message.
Jul 08, 2014 | NorStar M7310 Phone
PLEASE HELP!!!!!! DESPERATE!!!! M7310 NORSTAR - No one helped me with auto attendant but I figured it out. 1st greeting is you have reached... press one for touchtone... greeting is correct and says...
The problem you describe is not the fault of the phone, but a function of the Voice Mail system the phone is connected to. The solution previously posted is partially correct but each destination in the greeting table (the table entry associated with the number the auto-attendant recording tells the caller to press to reach a specific destination or feature) is assigned a function such as "info" or "forward" or a branch to another list of selections. If the selection does nothing then its configuration is incorrect, and it needs to be assigned to what ever function you want it to perform such as ring a specific extension, divert off to another branch of prompts, ring the attendant, etc. My suggestion is to get the model number and software revision on the Applications Module ("NAM") and post your question with as much detail as possible to the Nortel forum on the Tech Talk board at Sundance Communications (http://sundance-communications.com/forum/). Lots of well-seasoned professionals hang out there and I've always received very good support from posting there - they are equally respectful of old-timers and noobs and I've found them to be very professional and helpful with everything from simple mailbox glitches to a set-relocation function gone crazy. I'd give it a try.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Sep 30, 2013 | NorStar Meridian M7310 Phone
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
Incoming calls on Line 4 are ringing in personal office and mail line. I want it only to ring on Mail line . Our phone is a Norstar M7310. Thanks Sherrie
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
May 20, 2011 | NorStar M7310 Corded Phone
Call display won't work as the phone system M7310 keeps picing up on the first ring. I have changed the Auto Attendant and the ccr # of rings but that doesn't help
Try this - keep the handset in the cradle and press:
"Feature 9 8 2", the system will prompt you for a password.
The default password is: "O P E R A T O R"
Scroll through the items by pressing "Next".
The "Answer Lines" should be changed to N(o) to stop the Auto Attendant from answering. You will need to wait at least 2 rings for the system to process the Caller ID info & display it on the phone.
Good Luck!
May 13, 2010 | NorStar M7310 Phone
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Call Pilot voicemail Nortel
Depending what number your extensions start with, you need to go to the programming for the auto attendant and "undefine" the number in the menu. More than likely, it is built as a "thru-dial" and allows callers to punch in the extension. If you remove this, callers will have no other choice but to use the options in the menu. I can walk you through these changes if you want.
Apr 16, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Automated Attendent
Norstar Voicemail for 6.0 or less
Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG:", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Record the Company DAY & NIGHTGreetings:
1. Press AA
2. Press GRTG
3. Press GRTG
4. <Display> Greeting:
5. Enter 1 for DAY Greeting --- Enter 2 for NIGHT greeting
6. Press OK
7. Press REC to record.
Feb 25, 2009 | NorStar M7310 Phone
Nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
NorStar Meridian M7310 Phone Logo
1,590 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
