Question about A.O. Smith SQ1102 Pool Pump Motor
Motor is loud and makes a surging sound - A.O. Smith SQ1102 Pool Pump Motor
  • 1,389 Answers
THIS WILL HAPPEN WHEN BEARINGS START TO FAIL. IF THE MOTOR IS FAIRLY NEW ,LESS THAN A YEAR .RETURN IT ASAP. I HAVE FOUND THAT THE REAR END BELL CAN ALSO FAIL
IF YOU TAKE THE BACK COVER OFF AND SEE A BROWN OR BLACK DUST,IT IS THE END BELL GONE BAD 98% OF THE TIME. THIS CAN BE REPAIRED. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. COST ABOUT 75.00 ... WATER DAMAGE VOIDS WARRANTY'S.....JAY
Posted on May 09, 2010
    New Friend:
Check the impeller to difuser clearance. If the clearance is too great or the impeller is wobbling, the water can surge back to the inlet and cause a surging / vibration sound with the unit. Hope this helps.
Posted on May 16, 2010
SOURCE:
Loud rattle sound when Idling
I suggest you have your car checked as soon as possible - while a rattling exhaust isn't desperately urgent it could be the cat breaking up which might later restrict the flow of gases. Most importantly excessively loose timing belts or chains tend to make most noise when the engine is idling. If the noise is being caused by this delay could be very expensive.
Feb 24, 2016 | 2004 Lincoln Town Car
What would make my TV have a loud pop sound, screen went blank and does not power back up?
Has there been a power surge through the mains? That may have caused the issue and ruined your TV. I am not sure if the TV can be fixed if this is the case.
To prevent this happening again, plug any TVs, expensive desktops etc into a surge protector. This will prevent any power surges from the mains overloading and ruining your devices.
I hope this helps.
Jun 20, 2015 | Televison & Video
My dryers plug shorted out and tripped the breaker. I replaced the plug and turned it all back on and it worked.....then seconds later a loud poof sound from the dryer and now nothing is working. Please...
when a plug shorts out like your has,it creates a surge of current for a moment,it could have ruined or weakened the element,motor,thermal fuse or even pierced a wire electrically and when you re-powered the circuit it blew out this weakened component,the loud poof you stated sounds like the element burned through and blew out creating an arc and the poof sound
May 05, 2012 | Kenmore Elite HE4 Electric Dryer
While my model 632 cools fine, it does make a low frequency surging sound. This sound resonates throughout the house and is quite noticeable in some rooms while not heard at all in others. One time the...
this is not a problem with the unit but the unit AND your floor,the resonance is amplified by your flooring and can be reduced by putting sound deadening pads under the feet.foam/felt work best.
Did you load up the unit prior to the loud roaring noise?? because the noise was probably the compresor at the end of the freezing cycle..
Sep 16, 2010 | Sub-Zero 632 / S
I have central air (Amana). Is it common to hear a loud surge sound when the unit comes on. It was installed this summer.
Hi, this surge sound that you are hearing is probably the freon moving through the lines on start up, and if this is a heat-pump and not a gas fired heater you have on this central unit, when the reversing valve is energized in either the cooling mode or the heating mode, you will hear a loud surge of freon gas moving the sleeve in the valve to switch it from one posistion to the other.It is rather loud but should only last for a few seconds or so. If it continues to make this sound after start up, it should still be under warranty, so I would call them out before it expires to be sure its not any thing else. I am sure if you have a heat-pump, and you don't have a gas heater, its just the reversing valve shifting over that is making this surging sound as this is the sound they make. Please keep me posted if it gets worse or you are not sure, and please don't forget to rate me as I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 08, 2010 | Amana Heating & Cooling
Doesn't agitate or spin but makes loud motor sound
check your motor coupling, it is between the motor and tranny
Feb 17, 2010 | Washing Machines
Makes very loud noise at start up.
It sounds like the bearings are going bad on the motor. Does it make the same sound when it is running?
Aug 09, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Dell 3300mp Projector Loud Noise
Judging by the mains hum noise and now shaking it sounds as if a motorized component has broken.
Humming could have been the initial jam, then shaking the damaged part attempting to rotate.
Maybe check your cooling fan blades?
Dec 02, 2017 | Dell 3300MP Multimedia Projector
Surging and loud whistling noise
Sounds like a vacuum leak. Check all vacuum hoses on the intake, throttle body, etc. Sounds like one cracked or came off. Post back if you have any questions. Hope this helps.
Feb 08, 2009 | 1996 Chevrolet Impala SS
A.O. Smith SQ1102 Pool Pump Motor Logo
438 people viewed this question
Top A.O. Smith Plumbing Experts
Andrew Bugbee
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
